citroen relay van knocking noise
selectsands
i have noticed that when i am pulling away from stopped and am turning either left or right there is a rapid knocking noise, this noise stops if i depress the clutch. it also stops if i am travelling in a straight line, i have not noticed it at speed about 10 or 15 mph or more.....however not sure if this is related but when travelling at speed when i turn, more so when i turn left but there is a high pitch noise that is only in certain areas of turning, for instance i turn a corner and it skweaks but if i turn the wheel another bit it stops and then turn a bit more and it may come back!!!!! please help as i use this for work and need it run smoothly.. thanks ant
vince
- x 13
Inner CV Joint on its way out or driveshaft wear on the splines would be my guess.
When you depress the clutch the drive is diconnected from the transmission and likely any "slap" between the joint at the shaft under load will diminish.
How many miles has the van done?
selectsands
quite a few!!!
165450 and i just noticed on the last mot it has an advisory - possible suspension strut bearings, steering system tight....could this have anything to do with it or should i add it to the list of things that need attention !!!
uncle buck
- x 10
The strut top bearings do rust up & break up but this normally shows as a clanging / twanging noise when turning the steering....imagine the noise the coil spring jumping round in notchy movements as you turn the wheels would make.
Cheers
Cheers
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
selectsands
big thank u for your replies
may i just ask if it could be the struts and would the noise stop if i were to take the take the load of them by free wheeling (depressing the clutch) or do you guys think it would be likely to be the struts as well as something else, like the cv joint or drive shaft (as vince wrote)....can i perform a test to single one of them out. sorry to ask so many questions but i don't know much about mechanics.....don't suppose you may know how much any of these jobs may cost to repair....if they are not too complicated could i buy and replace myself???
really appreciate your help
thanks ant
thanks ant
uncle buck
- x 10
Free wheeling won't affect the load on the strut top bearings.
To test the strut top bearing get someone to turn the steering from lock to lock while you hold your hand on the coil spring , see if you can feel the spring sort of jumping around as the steering is turned. Compare the suspect side with the side that seems ok to see if there is any difference.
The spring should move around smoothly.
As Vince has mentioned the knocking noise sounds like a CV joint...can you not have a local garage have a drive of the van to try to give a diagnosis... as knocking noises can be hard to pin down without hearing them.
This is a strut top bearing I replaced on my ZX....it had just started to make a twanging noise when the steering was turned....it fell to bits as I was removing it...
Cheers.
Cheers.
selectsands
thanks again
thank you for info on strut i will check it out, i popped in on a garage near mine and they have confirmed that the knocking is the cv joint and they have said they will do both sides for £120, hopefully this is a good deal and solves the noise!
thanks for help and hope you all have a great weekend
ant
ant
uncle buck
- x 10
Huskyxantia
- x 917
Re: citroen relay van knocking noise
Arghhhh.... This story needs a good ending what happened ????
Husky.
Huskyxantia
- x 917
Re:
Wow look at the state ...uncle buck wrote: 26 Jun 2009, 16:43 Free wheeling won't affect the load on the strut top bearings.
This is a strut top bearing I replaced on my ZX....it had just started to make a twanging noise when the steering was turned....it fell to bits as I was removing it...![]()
Cheers.
How's it going now ??
I'm the sort of person who can't go without the end result lol
Husky.
uncle buck
- x 10
Well a new bearing was fitted and all was well.
I sold the ZX and moved onto anther French car, a Renault Laguna
