warm air con
scenicsi
warm air con
my 06 scenic dosent get cold when the aircon is on local dealer says its -5.5 degrees my other car gets really cold but the scenic just feels like the fan is on any thoughts
DoubleChevron
Your dealer is lying ... The only way you could minus 5 degrees from the vents is if it's -5 outside....
The air-con can never get to zero degrees, if this was allowed, the evaporater would turn to a lump of ice. (air-con dehumidifies, so if you have the evaporator temperature to low, the moisture on it will freeze, stopping any airflow).
If it doesn't feel like it's working.... It's probably not. Unless of course your mixer flap is stuck and and always guiding the air through the heater core.
seeya,
Shane L.
seeya,
Shane L.
'96 Big BX 2.1TD exclusive slugomatic (aka XM)
'85 CX2500 GTi Turbo Series II (whoo hooo)
'96 Xantia VSX slugomatic (sold !!)
and of course, lots of old Citroens, slowly rusting away in pieces
scenicsi
Xaccers
- x 188
Do you have individual climate control like I had on my megane and laguna?
DIY sphere tool
DIY sphere tool
