Help on rear seats please. (lost handbook)
Penguin
Unread post by Penguin »
Hi chaps
Really basic question this time. I've lost the rather tatty handbook that came with my Xant, and last week I had to put the seats down to transport stuff to the dump. I managed to get teh rear of the seats to fold down by pressing the big button but couldn't manage to pull the seat bases forward (tilt). I managed to lift them a couple of inches but couldn't seem to find any release mechanism.
I've got to take more stuff to the dump straight after work this afternoon so wondered whether anyone could point me in the right direction with this one?
Thanks in advance.
95 Xantia 1.9td SX
Xaccers
x 186
Unread post by Xaccers »
Seat backs in upright position ready for take off ;)
It helps to have the front seats moved forwards.
Grab under the front of the seat bottoms and lift directly up to tilt the front up.
Then grab the back of the seat bottoms (between them and the seat backs) and rotate the back of the seat bottoms up and forward so they are flat against the backs of the front seats.
Having removed the headrests (which can be stowed safely in the footwells behind the front seats), release them and fold them down.
DIY sphere tool
davetherave
x 4
Unread post by davetherave »
Lift the front of the seat bases directly up (ie nearest the front drivers an passengers seat), and they will raise about 3 inches, then lift the rear (where the seat belts come up up) up and forwards, job done.
Think that makes sense
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
Penguin
Cheers chaps, I never would have worked that out for myself!
Unfortunately Xac, my Xantia did not come complete with rear headrests. I will have to start trawling scrapyards!
95 Xantia 1.9td SX
x 94
Unread post by citronut »
i thought the base squabs have to go up at the front edge then forward before you can tilt the rear edge up
regards malcolm
Xaccers
x 186
citronut wrote:i thought the base squabs have to go up at the front edge then forward before you can tilt the rear edge up
regards malcolm
You're right, they do go forwards, but that tends to happen automatically when you lift the back edge up (or even just slip your fingers in the gap)
DIY sphere tool
Penguin
Jeez, it's so easy when you know how! Thanks for the help, I managed to get the tree to the tip no problem last night. I see what you mean about it being easier if the front seats are moved forward.
Cheers
95 Xantia 1.9td SX
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
:D I had the same problem when I got my first Xantia..
one day I got the bases up no probs, the next time I had no idea how to do it, felt pretty silly :)
