Xsara A/C
xsara
Xsara A/C
Unread post by xsara »
The airconditioning on my Xsara 1.9TD is not working.
There is no load on the engine when the a/c is switched
on so could be the relay or fuse.
Anyone know where these are located so I can check.
blueboy2001
Unread post by blueboy2001 »
Im not sure on the part locations, but be aware if the gas pressure or oil level drops too low then as a fail safe it compressor will not kick in, so it may not be solely an electrical problem.
Rich
Unread post by Rich »
Hi guys,
I will second what blueboy says, and if you are in the North Yorkshire area, i know an excellent air-con specialist. Did a full service on my system for under £80.
Cheers, Rich. Xantia Exclusive HDi.
sv4195
Unread post by sv4195 »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Rich</i>
Hi guys,
I will second what blueboy says, and if you are in the North Yorkshire area, i know an excellent air-con specialist.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Who is it, pray tell. My Xantia needs filling up about every 18 months and I pay £50 for the privilege(!).
xsara
Thanks guy's - I would still like to do a quick check of the fuse
and relay if I can find them !.
It worked fine when I bought it a year ago but just tried it now
and nothing.
I'm in Cardiff area if you know of any cheap/reliable fix it places.
Rich
Hello sv4195, Allan,
The company is called Technical Car Services and they are in York, the address is;
17 Alexandra Court,
James Street,
York,
YO10 3DP. Telephone, (01904) 412742
He did an excellent job on my Xantia, well worth the money!! Nothing was actually wrong with mine, but i had just got the car and wanted to have the air-con serviced so i knew that it was right, peace of mind and all that! I will have mine checked every year i think. Hope this is of help Allan.
xsara
So no one nows where the A/C relay & fuse are located ?
