My(M reg)306 XL's central locking locks when activated on the key fob but unlocks immediatley with the indicators flashing. I have tried another relay from a scrapper but no joy.
I have ensured the linkages on the doors/hatch are free and lubed.
Syptoms similar to leaving a door partially open.
Can I isolate 1 door at a time, remove the conn block, when the locking works that is the door at fault.
Anybody have any suggestions??
Ash[?][?][?]
306 central locking
- x 1060
apsbaketcase
Dave Burns
- x 3
There are switches in the door locks to supply lock position info to the central locking controll.
Unless you can see the designated cables on a wiring diagram I suggest you take the drivers door to bits and check the operation of the switch in the lock.
If it turns out to be the duffer all well and good, if its ok make a note of the switch cable positions in the connector so you can identify and test the remaining doors without having to take them apart.
Dave
Dave
