rev counter
Bren
rev counter
Unread post by Bren »
does anybody know where it connects to the gearbox? Mine has become intermittent, especially when the engine is hot and I need to investigate.
96'Xantia 1.9 td estate
93'gsxr- 750
85' Rover 3500 (work in progress)
x 1489
If it's a pre-ECU 1.9TD we are talking about, then it's on the flange on the back of the flywheel end of the engine, above the O/S driveshaft - held in with single 10mm bolt. Bit awkward to get to :? I think there is also a brown connector on top of the engine somewhere.
firstrebel
Unread post by firstrebel »
Do not use a ratchet spanner to take the bolt out as it will foul against the drive shaft and you won't be able to get the spanner off the bolt when it is undone, and you won't be able to remove the bolt not sensor. Use an open ended spanner.
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
vince
x 13
Unread post by vince »
RichardW wrote:If it's a pre-ECU 1.9TD we are talking about, then it's on the flange on the back of the flywheel end of the engine, above the O/S driveshaft - held in with single 10mm bolt. Bit awkward to get to :? I think there is also a brown connector on top of the engine somewhere.
Also it can be found there on an ECU equipped 1.9TD, as we discovered on mine last weekend :wink:
x 1240
Unread post by Peter.N. »
The problem could well be to be caused by the 2 pin plug on the lead from the sensor. End of the cylinder head just above the gearbox. Give it a good clean and a smear of grease
