Have now replaced all the spheres on 1.9td estate in last 10k.
The two rear ones I did today. I suspected them less than perfect. Reason was that on going round slow corners with very rough holes in road you would hit one a certain way and get a loud thump which went through the car...............as though you had hit a huge pothole.
I was disappointed that no pressure of fluid rushed out of any of these two spheres to indicate a rupture. Have only taken car a short journey and seems to ride smoother (Placebo Effect ?)so we will monitor it.
Thing is I get that creaking from time to time on parking. I thought it may be because car is on a slope?
So why do radius arm bearings creak, and why do they bang if there is no apparent play. Is there rubber somewhere in there that has failed ? (steady guys) .
Wheels look vertical with a square on them.
There is a nut on subframe that you see if you look between tyre and wheelarch........it sits in the same plane as a wheelnut. Is that where lthe bearing is? Give me a run down on replacing procedure anyone?
Radius arm bearings?
lexi
- x 134
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
rory_perrett
If you do a search for arm bearings it will throw up loads of info.
No rubber involved, but the bearings can collapse meaning that surfaces than shouldn't come into contact with each other do.
On my BX the wheels would obviously lean every 100k miles or so signifying that the bearings needed changing.
On my Xantia the car was passed 200k miles with no sign of bearing failure, however strange rear tyre wear reminiscent of a faulty shock absorber lead me to wonder if the bearings were shot. When I changed them they looked to be in fairly good condition, certainly nothing like the BX where I could find a pile of rusty shrapnel where the bearing used to be, but the strange rear tyre wear was cured and the back of the car felt better.
If I remember rightly, the estate uses the same basic bearing as the Hatch (and BX) but different seals meaning that the kits from GSF don’t give you all the bits you need.
Main consideration in doing the job is that you can easily write off the ABS sensor(s) at £60 a shot while trying to get them out of the arm. There is a thread on that as well. I would recommend disconnecting them at the connector on the top of the sub-frame and don’t try getting them out of the arm.
Basically its –
De-pressurise
Remove sphere
Remove suspension cylinder
Disconnect roll bar (Torx required)
Disconnect brake calliper (or remove calliper from arm)
Remove suspension arm bolt.
Remove arm.
Getting the bearing races out of the arm is much easier if you have access to a welder and can run a bead of weld round the race. When it cools it contracts and the race can often just drop out.
Not too bad a job.
Best of luck.
Basically its –
De-pressurise
Remove sphere
Remove arm.
Not too bad a job.
Best of luck.
- x 1238
It could be the suspension cylinder thats creaking, the front ones do. If the radius arm bearings are worn, as Rory said you should have uneven rear tyre wear and you should be able to feel movement on the wheels when jacked up.
I have had them fail on BX's and CX's but never on an XM, about the same ilk as the Xantia. Failure is caused by lack of grease so when I have replaced them I have filled the tube between the bearings with grease, never had them go again.
lexi
- x 134
Thanks guys. Tyre wear is even. Could be the cylinders. Will test car further to see if thumping continues with new spheres.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 94
the only thing i will add to rory_perrett job description is you dont need to remove the sphere/s or susp cylinder/s,
just with the car properly supported and susp depresureised, jack up one of the rear arms slowly and fully, but gently so not to tip the car off the stands/support, doing this will allow you the move the susp push rod back well clear of the trailling arm
regards malcolm
regards malcolm
- x 1238
steelcityuk
- x 1238
- x 94
- x 1238
Hi Malcom
I had one out last week as the ABS sensor had gone o/c and it was cheaper to swap the arm. I struggled every which way to get the arm out but it wouldn't come past the cylinder, then I read the Haynes BOL and it told me to take the cylinder out, which I did, and it came out a treat. I have just looked in the Xantia book and it also says you have to remove the 'suspension hydraulic unit' so I must have missed something.
lexi
- x 134
Ok guys lots of good stuff to mull over. I would imagine that towing caravans would put the pressure on these bearings.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
- x 94
- x 94
- x 1238
Hi Malcolm
Its actually a home made ramp. Our land is on a slope, there is a level area of concrete alongside the garage with a wall at the back about the height of an oil drum, you can drive to the top of the wall I then have two large pieces of timber about 8' long, the far end of which are supported by two oil drums. Sounds crude but its very effective. It puts the wheels just at the right height to work on brakes, suspension etc and I have a stool to sit on which gives me just the right height to work underneath - worth its weight in gold.
I have just replaced the timbers as after about 35 years they were beginning to go a bit rotten.
I have two small trolley jacks that I can use on the ramp to raise either or both sides
In answer to your question - yes, there was sufficient clearance to drop the arm right down, what happened if you tried to tilt it right down, was the projection that goes between the bump stops stopped it from being withdrawn. I could only pull it out straight but the suspension cylinder was in the way. Is the Xantia different?
