sorry dozy question but i havent got a manual for it.... goes the nearside high beam headlight have its own fuse....if it does what fuse number is it (oh and where is the fuse box )
cheers
peter
M reg xantia 1.9td 266000 miles expired
R reg xantia 1.9td 186000 miles veggy power expired
L reg renault clio 1.9D 91000 miles expired at 107000 miles
x reg clio 15d veggy power bottom of the car rotted through
06 c5 2.2 TD wowser so much power and comfort 160000 miles
The Fusebox concerning the headlights is situated in the engine compartment & are as follows F12 = LH Main beam. F13= RH main beam. F14 = LH Dipped beam. F15 =RH Dipped beam. All are 10A Fuses. The fusebox in question is situated beside the battery. Another fusebox (not applicable to the headligts) is situated uncer the facia, on the passenger side.
