Long term project question, The fuel pump on my DS23 EFi failed does any one know what the delivery pressure should be for this system? I think it is a bosch J tronic. Suggestions as to what modern fuel pump would make a suitable replacement.
The alternatives would be to blank off the injectors and put a carb on the end of the air intake, or if I have to do a total engine re build which is a possibility, fit the whole fuel injection and ignition system from a latter CX to it
DS 23 EFi fuel pump
rsdavies
DS 23 EFi fuel pump
Must learn to weld and fix the DS23
DickieG
- Monaco's youngest playboy
- x 33
