2.0 hdi cambelt change
sportingfiat
Unread post by sportingfiat »
i`m looking at changing my cambelt in next few weeks having never touched a diesel im after some pointers :)
do you need a cam locking tool or is there a simple way to do it????
cheer
andy
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The cam locking tool on an HDi is simply a couple of bolts (M8 IIRC) there's no need to lock the pump as the HDi uses common rail injection, to lock the crankshaft I found it easier to insert a length of suitably bent copper brake pipe from below.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
XantiaExclusiveHDI
Unread post by XantiaExclusiveHDI »
Hi Andy
A few of us have done this recently... Have a search first to pull up the threads - a little about my experiences can be found here:
http://www.frenchcarforum.co.uk/forum/v ... highlight=
Toby_HDI changed his not so long back.
A BOL will help for sure - although some things aren't as they would have you believe!
Chris.
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
DickieG wrote:The cam locking tool on an HDi is simply a couple of bolts (M8 IIRC) there's no need to lock the pump as the HDi uses common rail injection, to lock the crankshaft I found it easier to insert a length of suitably bent copper brake pipe from below.
Meaning the locking hole for the crank is - Yes Behind the starter!!
You CAN ALSO use a 6mm allen key! I can insert that in the XUD eyes closed now with dooing so many, but Im sure the HDi is in the same place. Dont forget a new Belt eccentric tensioner as a matter of course! These new plastic feeble things are not like the XUD's strength, where all cam belt rollers were metal - none of this plastic rubbish - Oh the days!!
Paul
A very sad...
1994 XM 2.1 d auto
DickieG
x 33
Paul
The locking hole location is the same as an XUD its just that on an HDi its far easier to reach it from below.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
sportingfiat
right ordered a full kit new tensioner etc
has anyone got an easy way of lining it all up so i know im right???
or is there a how to anywhere ? ?
cheers
andy
