Xantia Caliper drag
lexi
x 133
Xantia Caliper drag
Unread post by lexi »
I`ve got a very slight drag on the 1.9td estate. Rear N/S.
I have had a go with die grinder to remove ridge at inside circumference of disc. I thought the pads may be sticking on it. The squeak is intermittent. Never get it when raining or roads are wet.
IME N/S rear calipers get more of the grunge and seem to give trouble as a result. I have already renewed a front O/S but that was deffo seizing.
Anyone had issues with the slide before I go back in again. The discs and pads are within spec I think.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1240
Unread post by Peter.N. »
If its only squeaking and not getting hot, I wouldn't worry about it. The only thing you can do is take the piston out and clean it. You might get away with squirting some fluid in under the dust seal and levering the piston in and out to free it up.
x 94
Unread post by citronut »
sounds like the imfamous corosion build up between the calliper and susp arm, remove calliper clean/remove corosion them follow steve's (myglaren) sudgestion of placeing a thin plastic membrain and grease between calliper and arm, to try and prevent further build up
regards malcolm
dieseldoggy
Unread post by dieseldoggy »
on mine when it did that i zipp wheeled it all clean and copperslipped it so nothing gets behind it.or you could try that black?grease they use on marine or such like that is imper to water
xantia 19td estate 96-7
x 94
i think it was AndersDK said alloy and copperslip react against each other, so maybe its not good to use it at this point
regards malcolm
lolingram
RIP 2010
Unread post by lolingram »
This is the way to go, since the problem is essentially electrolytic in nature. Isolation is needed between anode and cathode, and the electrolyte, which in this case is the contaminated water and salt over the years.
R.I.P. January 2010.
XM 2.1 auto VSX 1996 - Bosch Inj, Xantia HDi 90 estate 1999, Xantia 1.9TD 1997
Previously...
GS 1970, Dyane 1974, Xantia 94 VSX TD, XM 94, 2.1 auto - Lucas Inj, XM 92 2.1 estate - Lucas Inj
