Foglight Removal Xantia HDI
jmd
Unread post by jmd »
Has anybody got any advice on removing a foglight (offside) There are 3 bolts holding it in place the lower one is no problem, and the one on the side of the wing troublesome to a lesser extent. However the top inner bolt seems almost impossible. Definately the manufacturers never considered that a replacement would ever be necessary. At this stage I have removed the headlamp, but have not succeeded in getting any closer to a solution. Any advice gratefully appreciated
x 1489
I believe it's a bumper off job.... :cry:
Toby_HDi
x 3
Unread post by Toby_HDi »
Officially it is a bumper off job. I found I could access the fogs by removing the front grille and lamp units and then you can reach down to the fogs. A torch may be useful.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Stempy
Unread post by Stempy »
Yes, taking the headlamps out is the quickest way in, other than that it's bumper off. :(
Lexia ponce
jmd
Thanks for the advice. Removed one headlamp & it was still "a bumber off job". Well partly off - loosened one side of the Bumber & pulled it our about six inches. Although I managed to looses the bolts on removing the headlight, the problem was to remove the old lamp & inserting the new one. So it was necessary to partly pull out the bumber. Job done. Lets hope it is not necessary to do this again. Replacement Lamp = € 120-00 here in Ireland. Fortunately I had a lamp from my now partly scrapped 99 Xantia.
