Xantia reverse lights, weird problem.
gotanothergrot
Unread post by gotanothergrot »
Reverse lights have not been working for some time so decided to have a look today. I decided to try a test light to establish if any power was getting through.
so with the tailgate raised ,trim removed wires exposed, next thing to put gear shift into reverse, ok now put side lights on................"what the" ignition is off at key and the whole dash, ignition ect all lights up.
Take out of gear, ignition goes out put in gear ignition comes back, twist light switch off ignition goes off.
I dare not try that again encase i blow something, i can live without reverse lights for now.
Has any one experienced a similar problem, and how do i fix??
x 8406
The clue here could well be in the tailgate being up. I'd not be surprised to find that you have broken and chafted wires in the concertinas up by the hinges causiing the issues you're having.
Pull the concertinas back and have a look.
If it will help, I can post applicable wiring diagrams. They're a little different for the estate and to be sure of accuracy, I'll beed your RP number and exact model.
gotanothergrot
Thanks for the quick reply CitroJim i didn't consider that, will post what i find Later.....
Graham
gotanothergrot
This is what i found Jim,
Repair with self amalgamating tape and a block connector.
Hope this is good enough!!
.Image
Thanks for pointing me in the right direction.. :)
gotanothergrot
x 1489
Pretty conclusive then.... :lol:
One of the jobs I have to do is find out why the HRW on my estate doesn't work any more - I suspect I will find something similar :cry:
gotanothergrot
Under the plastic trim just above my photo is where the faston connector is located for the HRW, i unplugged mine to gain a bit of slack, it may just need tightening.
x 8406
Excellent work Graham :D
Yours had gone rather worse than they usually do. Your tailgate must have seen plenty of use over the years - up and down like a fiddlers elbow :lol: :lol:
gotanothergrot
:D
reblack68
Unread post by reblack68 »
When I do a repair like that I prefer to attach a length of new wire to the cut ends, then shove the repairs well into their respective cavities so that it's new wire getting flexed, not the repair.
Richard
Care of a 1994 205 D.
gotanothergrot
I didn't think of that, why is it that the obvious most practical solution often eludes us.. :?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
The polymers in PSA cars seem really temperature sensitive.
I'm yet to see anything like the insulation cracking evidenced, yet my estate tailgate goes up and down many times daily. It must just be warm enough here for the plastics to flex more.
x 1489
Had a quick look today - sure enough, just the same as Graham's pictures (not quite as bad!) Red wire is broken (presumably the HRW feed) and the heavy green wire has broken insulation. Another job to tackle then.... Wonder why it affects the estates more than the hatches - perhaps the estate door works through a larger angle?
