Hi
I am new to the forum so please forgive if this has been raised before.
I have a 1994 ZX 1.9 TD. Its a good car and I don't see any reason to change it for a newer one. The only downside is that it can be very very smokey after it has sat idling, even for a short while. The smoke appears during the initial pull away and might be when the turbo kicks in ? The smoke is grey / white and is possibly oil ! Whilst running normally it seems to be fine and there is little noticeable smoke.
I changed the oil and added a bottle of Wynns Stop Smoke oil supplement and this cured the smoking for a few months. Unfortunately it started smoking again and I had to add more Wynns !
Is this a common problem and can it be easily fixed ? Or is it something more serious like a worn turbo or fuel pump ?
Forgot to mention the car uses very little oil and the coolant never needs topping up
Cheers
ZX 1.9 TD Very smokey after sat idling
steelcityuk
jonathan_dyane
- x 8403
Welcome to the forum ajswiss
Another possibility if the engine has a Lucas DPC injection pump is that the pump has a split boost overfuelling device diaphragm. This is the circular device on the front (as you look at it) with a pipe leading up to the intercooler.
This can be proved by disconnecting the pipe temporarily and seeing if the smoke clears.
If you disconnect the input hose to the intercooler, this will isolate the turbo as a cause.
ajswiss
firstrebel
My brother had a Transam when he lived in the Bahamas and it smoked. He used Wynn's to stop/reduce the smoke. It does not cure the problem just blocks the gaps caused by wear or damage or component failure. It is very temporary.
Bob
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
- x 94
vince
- x 13
