Hi Guys,
Does anyone know if I unplug the EGR valves on our Xantia HDi if it will trigger the engine management warning?
Someone has told me the EGR valves could be what is causing the car to smoke.
If it does I know someone with an ELIT machine, will this work on a 2000 Xantia?
A friend who looked at it reckons it's running rich as it's smoking slightly at idle. It's an unburnt diesel smoke from it too.
It's had injector cleaner through it a few times now and it's made no difference.
David.
Xantia HDi 110 EGR Valves
DHallworth
- x 167
'98 Xantia Activa V6
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
steelcityuk
I would be surprised if unplugging the valves didn't trigger the EML. This isn't a foolproof check either, if the valve itself is leaking unplugging it will make little difference. It would be better to remove the valve and fabricate a blanking plate - if only for test purposes.
Sorry don't know about the Elit.
Steve.
Steve.
not applicable
- x 1055
DickieG
- Monaco's youngest playboy
- x 33
Why not simply unplug the vacuum hose running from the solenoid and insert a plug in the now open end of the hose? I've done it on mine since I bought it and haven't had problems or any codes being triggered
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DHallworth
- x 167
DickieG
- x 33
DHallworth
- x 167
Hi Dickie,
Thanks for the advice.
I am unsure as to which hose you reckon I should unplug so I took a picture of the valves on our car and labelled each hose 1 through 4.
Could you tell me the number of the hose that I need to unplug?
David.
David.
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
'00 XM V6 Exclusive
'15 C4 BlueHDi Feel
steelcityuk
DickieG
- x 33
Number 1.DHallworth wrote:I am unsure as to which hose you reckon I should unplug so I took a picture of the valves on our car and labelled each hose 1 through 4.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
DHallworth
- x 167
