Activa 0-60
XantiaMan
x 18
Activa 0-60
Unread post by XantiaMan »
I was lucky enough to borrow a friends private road on his farm... so decided to do a 0-60 in the Activa to see what it looked like. Wheelspin in 1st excepted, i make it a fraction under 8 seconds, which is not bad for 3 up and hot air!
2020 Peugeot Partner
2017 Fiesta ST
2001 Ford Puma 1.7 VCT
2006 Ford Fiesta Zetec
http://www.facebook.com/kidmans" onclick="window.open(this.href);return false;
addo
Sara Watson's Stalker
x 95
Unread post by addo »
How far off true, is your speedo at 90MPH?
Just curious. My estate would be battling by that stage of the speed you reached.
Koukku
x 8
Unread post by Koukku »
Not bad at all. I tested my V6 a while back with RaceChrono, and got 8.2 seconds (0-100km/h). I got wheelspin through 1st gear, and hit the limiter on 2nd before I realized that I needed to switch to third to actually reach 100km/h. :lol: Well, atleast I reached the time given by the factory. :P
According to the speedo it hits 100km/h in 2nd easily, but when my speedo is showing 100km/h I'm actually travelling about 88km/h... :roll:
- Previously Activated -
Xaccers
x 188
Unread post by Xaccers »
Talking of speedos, comparing with my tomtom, it's about 5 over until around 90mph, then it can be as much as 10 or so over, but returns to bang on at 120mph :oops:
DIY sphere tool
anybloodybody
Unread post by anybloodybody »
I took my CT to the French Car Show in May 2004.
I have a printed record of 0-60 sprint time of 9.41 seconds, and a quarter mile time of 16.82 seconds (two up with standard factory boost).
Dunno what the times would be with my boost cranked up?
Anyone know what Citroen state is the 0-60 time of a standard CT?
I was gonna take my CT to this years' FCS, but i'm not gonna bother now, 'cause they dont have the laser sprint lanes set up this year.
No lean machine
KevMayer
Unread post by KevMayer »
When compared to my Navman sat nav, my Activa was doing:-
Speedo / Navman
30 / 27
50 / 46
70 / 65
90 / 82
So, my Activa speedo is a bit optimistic.
When doing the same test in my C5, the C5 is spot on with the Navman.
Cheers, Kev
addo
x 95
Kev, could you post some corrected numbers for 110 and 130, please? I'm trying to see a trend. :wink:
Sid_the_Squid
Unread post by Sid_the_Squid »
Speaking of performance times, does anyone frequent Santa Pod?
I don't have an Activa, but fancy taking the 'green goblin' along sometime this summer wondered if anyone fancied a mini meet up.
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
x 5679
Sid_the_Squid wrote:Speaking of performance times, does anyone frequent Santa Pod?
Bryggsygtt does. See his Tales of a white van man! Some Santa Pod photos among that lot - including the last few
XantiaMan
x 18
I go to Santa Pod when i can. I went last year in the Activa.
2017 Fiesta ST
Brigsygtt
Unread post by Brigsygtt »
Aye ive had a few runs down the pod in my time :D Class day out if the weather is good 8)
Worked out the 0-60 on me van off my qtr mile times, 4.6 on slicks & 5.3 on road tyres, not bad for a box on wheels :lol:
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
Sid_the_Squid
That’s dam fast!
With road tyres thats 2.2 seconds faster than the fastest car I’ve ever driven or been driven in!
That has to be some kind of record for a van? You going to put that lump back in a R5 at some point, I’ll wager with some of that new fangled aerodynamics could shave another .5 second off the time.
Past Citroens
'97 Xantia 1.9D sx
x 5679
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
There's a significant difference in accuracy between S1 and S2 models with S1's being pretty accurate (my VSX is spot on) whereas with S2's you can add 5+ mph which is more than likely due to the jump the speedo needle does as soon as you move off.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Sl4yer
Unread post by Sl4yer »
DickieG wrote:There's a significant difference in accuracy between S1 and S2 models with S1's being pretty accurate (my VSX is spot on) whereas with S2's you can add 5+ mph which is more than likely due to the jump the speedo needle does as soon as you move off.
That isn't just mine then! Slams shut when coming to a stop too. Mine reads about 86mph at an actual 80, so you're probably not far off. I'd measure any 0-60 test to 65 on the clock. Or even more given that the standard is now 0-62.
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
