Quad valve DOHC Cadillac V-8 with FWD transaxle and the wiring harness...
http://cgi.ebay.com/ebaymotors/_W0QQitemZ220417113859
Yours for USD$3500 plus freight. What a "sleeper" it would be with LX badges and Activa hydraulics!
Will it fit a Xantia?
- x 8457
Well, the question of fitting can be simply answered after running a tape across my V6 engine and transmission. Basically, if the whole engine and transmission occupies no more than a metre cube then it'll fit a Xantia engine bay...
Exhaust is in about the right place as well but getting the driveshafts right may be interesting....
DickieG
- Monaco's youngest playboy
- x 33
fatherjack2002
- x 5
They shoehorned one into a Golf, so a Xant should be a doddle
http://www.cwstuning.com/gallery/coupe- ... dfrontshot
1995 Xantia VSX 1.9 TD, RIP
N*ssan Pr*mera . HATING EVERY MILE
1994 Xantia LX 1.9TD, RIP
1997 Xantia desire 2 re-homed
2002 Pugeot 307 HDI (not quite a Xantia, but still French)
addo
- Sara Watson's Stalker
- x 95
That was my thinking.
I imagine it would be hard on driveshafts, as you'd have to set the transaxle centreline back a little from GM's designed position due to the shorter engine bay.
The other snag could be hydraulics - if they normally run electric assist steering you'd have to work out how the pump might be operated.
ACTIVE8
- x 6
red_dwarfers
- x 58
