Guess the part that fell off!
Toby_HDi
x 3
Unread post by Toby_HDi »
Can anyone confirm that the following parts are in fact from the auto tensioner and not somewhere else? They were found wedged between said tensioner wheel and the belt.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 1044
Unread post by wheeler »
Looks to me like bits of the crankshaft pulley broken up.
wainy
Unread post by wainy »
These bits remind me of what happened to a Pug 206 1.9 Diesel I had a while back. The fan belt failed and bits of it, looking suspiciously like your photos, wedged themselves between the cam belt and one of the pulleys.......... the belt jumped a few teeth, the valves hit the pistons and you can imagine the rest!
So, my guess is that you are right :?: . Hopefully you have been luckier than me.
WAINY.
WAINY
2016 C4 Picasso Exclusive (Black)
1983 GSA X1 (Black - being restored)
Toby_HDi
x 3
Just to add, the items in question are metal.
The belt is intact (how I don't know :shock:)
Toby
Previous:
steelcityuk
Unread post by steelcityuk »
I'd go for crankshaft pulley too! Common fault if it is.
Steve.
not applicable
red_dwarfers
x 58
Unread post by red_dwarfers »
Looks nasty Toby :shock:
Saying that, I better check my dual mass crank pulley as I seem to remember it cracking slightly a few months back.
Kev
'19 C4 Cactus 130 Flair
AndersDK
Unread post by AndersDK »
Hi -
If these sheet metal bits were to be missing from any running part - that part would no longer work - period.
Also the crank pulley is not made of sheet metal, but cast iron or forged steel material.
To me it looks much more like a sheet metal cover - or simply foreign pieces of debries - that has been in contact with the moving parts.
Anders (DK) - '90 BX16Image
x 1044
Anders, on the HDi engines it's not a solid pulley, its a moving damper type.
Im still 99% sure its the bits of the crankshaft pulley. If you take the belt off you'll find that theres a bit of play in it.
broyty
Unread post by broyty »
Hi
I agree with wheeler this looks like the crank pulley is breaking up a very common problem on the hdi engines
cheers
Mick
1995 cit xm 2.0l turbo exclusive hatch auto
1998 cit xantia 1.9 td exclusive estate auto
1966 lincoln continental 2 door 462 ci
1969 chevy impala 4 door ht sport 350 ci
Toby_HDi
x 3
I guess I need to get the pulley off and have a look at it then....:(
Toby
Previous:
XantiaExclusiveHDI
Unread post by XantiaExclusiveHDI »
Blimey Toby - and you only recently had to replace your timing belt too? Still on the upside you'll be familiar with the work required :)
Here's hoping you find the problem and have some fault free motoring!
C.
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
Toby_HDi
x 3
Well, the crankshaft pulley looks absolutely fine. Have just taken it off to have a look.
Still don't know where it came from then...car now rattles too :(
Toby
Previous:
steelcityuk
Try painting a line across the crank pulley so you can check in a day or two just to be sure.
Steve.
not applicable
x 1044
Toby_HDi wrote:...car now rattles too :(
Thats what they do when the crank pulley has gone.
Toby_HDi
x 3
Its strange as the crank pulley looks absolutely fine. All intact. I took it off yesterday to look. Just makes me wonder where the metal came from.
Toby
Previous:
