Dipped beam activates head light washers!
Sid_the_Squid
Unread post by Sid_the_Squid »
Hey all,
Well tried to drive my new V6 at night for the first time about 10 mins ago, and found a weird electrical gremlin, when putting on dip, the head light washers are activated, and won't turn off, just the headlight washers.
I can operate the windscreen washers normally, the headlight washers go off as soon as dipped is switched off (did not even try full beam).
if its relevant, the dash indicator for dip beam does not illuminate, but all the general green dash illuminations are there, oh and the fans do no stay running for the usual few seconds after killing the ignition after running with the AC on.
I'm guessing this must be caused by a 'bad earth' somewhere, any ideas where to start looking?
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Stempy
Unread post by Stempy »
The headlamp washer timer relay is in the fuse box in the engine bay (well it is on mine). If you have a BOL there is a wiring diagram for the relevant circuit. Pulling the relay should stop it squirting as it wired so that it'll give a timed squirt only when the dipped beam is on when you clean the windscreen. Might be corroded connectors in the engine bay fuse box, be a good place to start anyway.
Lexia ponce
Sid_the_Squid
It gets weirder.
Taking your advice, I looked for corrosion on relays or fuses, everything looked nice, I even checked all the grounding wires next to the battery, all very clean.
I found the headlight washer relay, it was the one of the far left in the under bonnet relay section, if i take it out i can use the lights fine.
I changed around relays with some of the fan relays (which also look nice and clean) to test for broken ones, same results no matter what combination. So I decided to remove fuse 'F10' from the under bonnet fuses, this one is labeled 'head light washers', figured its better to remove a fuse than pull a relay, and now the weirdness kicks in. With the fuse removed the headlights work without starting the headlight washers, but the headlight washers also work when the windscreen washers are activated!
How can the headlight washers work, when their fuse is removed?
Insanity?
Upshot is I can use the car as normal, but would really like to understand what is going on here?
Before I have never had an issue with car electrics, I always believed the old 'French cars have rubbish electrics' stereotype was a myth, but this has really hurt my brain.
I don't have a BOL, in fact I've been trying to figure out what a BOL would be, heres my top 3.
1. Books online
2. Brilliant ornithological site
3. Beautiful old lady
Seriously though where can I get one of these 'bols' from?
Past Citroens
'97 Xantia 1.9D sx
x 5626
1. Books online
Try here
The bitter tangerine is the best one though :D
Sid_the_Squid
:lol: :roll:
Past Citroens
'97 Xantia 1.9D sx
x 5626
This is what the BOL* actually refers to.
Can be helpful or on the other hand it can just as easily lead you woefully astray.
*Book Of Lies :)
Stempy
I actually have a BOT, which is a genuine Citroen wiring manual, and F10 is the headlamp on information supply to the timer relay. F6 supplies the timer relay power on pin 5 and the switched supply to the pump exits the relay on pin 3. So by removing F10 you are telling the relay that the headlamps are off which should stop it working, so I would say that you have a duff relay.
Lexia ponce
Sid_the_Squid
*Book Of Lies
Ahh, would not have guessed that, I have two Haynes manuals for the Xantias, the early one which does not cover the HDi, and the later one which does.
Neither cover the V6 though, I just assumed that everything in the V6 was different, a silly assumption I guess. :oops:
I'll get some new relays tomorrow, see what happens.
Past Citroens
'97 Xantia 1.9D sx
Stempy
Remember the washer relay is specific to task and has timer and logic circuitry built in, so standard relays wont do the job. Don't know where you'd get one other than from Citroen or a scrappy.
Lexia ponce
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
The washer relay is also the best part of £30 :(
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
Sid_the_Squid
Ahh, that might explain the problem, from what I can see the relay which is in the washer relay position is exactly the same as the three ones which control the radiator fans, the pins, the serial numbers and wireing diagram on the side.
I'm suspecing that at some point the correct relay was replaced with this 'standard' one. Looks like a visit to Citroen Hatfield for me this lunchtime. :)
Thx all.
Past Citroens
'97 Xantia 1.9D sx
DickieG
x 38
The headlight washer relay is a large pink one.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Sid_the_Squid
Quick update, just come back from Citroen Hatfield where we managed to identify the relay which was required, its certainly not the same as the one I already have in the car, but I did not purchase the new relay this time....
Why?
Because it was £46.67 inc VAT :shock:
Still I've got the part number now, should it be needed in the future. its 655551 if anyone is interested.
So I am officially on the lookout for one of these relays, if someone is breaking an exclusive. I'll post in 'for sale & wanted' as well.
Thx for all your help guys. :)
Past Citroens
'97 Xantia 1.9D sx
Stempy
Rory Perret is breaking an exclusive with the winter pack so might be worth PMing him.
Lexia ponce
Sid_the_Squid
Stempy what's Rory Perret forum alias?, can't find any forum user with that alias.
Thx
Past Citroens
'97 Xantia 1.9D sx
