Ghost warning lights
firstrebel
Unread post by firstrebel »
On several occasions yesterday two warniing lights flashed dimly for short periods. They are not in the handbook and they do not light up when the ignition is switched on. They are in the top left of the bank of warning lights on the dash. They were orange. Because I was driving I could not look at them too long to identify the symbol, and they were not there long. Any ideas?
Bob
Robert Isaac
1997 Xantia 1.9TD SX Estate. 152000 miles
1995 Volvo 855 T5 Auto - Chipped. 186000 miles
davetherave
x 4
Unread post by davetherave »
One of them may have been the engines self diagnostic light, mine comes on above 1900 revs when my filter is clogged from veg oil!!
thing is its a bit difficult to say why it came on :? . Where there any other symptoms, like a drop in power etc?
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
firstrebel
I am about to change the fuel filter today. I can't comment on any drop in power as I can only assume it is running as it should. Since my other car is a 280bhp Volvo I have to 'detune' my level of expectation about its performance.
Bob
Robert Isaac
Clogzz
x 40
Unread post by Clogzz »
Any of these ?
Image Image
2002 C5 2.0i AL4 239,000 km 76372389
firstrebel
Not sure, I only had a quick glance and they were faint and flickering. I will see if it happens again and try to get a longer look.
Thanks.
Bob
Robert Isaac
dnsey
x 19
Unread post by dnsey »
'Faint and flickering' suggests a poor earth somewhere in the instrument panel wiring, or possibly one of the isolation diodes within the panel beginning to fail.
It'll either get worse, or never happen again :D
Sl4yer
Unread post by Sl4yer »
I'm sure I've read that some later cars have an excess boost warning light. Could that be one of them?
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
firstrebel
dnsey wrote:'Faint and flickering' suggests a poor earth somewhere in the instrument panel wiring, or possibly one of the isolation diodes within the panel beginning to fail.
It was only these two that were faint and flickering. All the others are OK.
Bob
Robert Isaac
firstrebel
Sl4yer wrote:I'm sure I've read that some later cars have an excess boost warning light. Could that be one of them?
I don't think so, I was on a light throttle in 2nd gear about 5 minutes after starting in the morning.
Bob
Robert Isaac
firstrebel
One of these came on again this morning, and in fact stayed on when I applied the handbrake at traffic lights. It is the worn brake pad light. Don't know why as the front discs and pads were changed only a few weeks ago.
Bob
Robert Isaac
dnsey
x 19
More than likely a pad contact wire has been incorrectly routed, and severed by the disc. Very common!
firstrebel
Thanks. I'll check over the weekend.
Bob
Robert Isaac
firstrebel
It was the offside outer pad wire. The rubber thingy that holds both wires had flipped open and the wire was close to the disc, and apparantly touched it with vibrations and movement.
Bob
Robert Isaac
