405 running issues
Toby_HDi
x 3
405 running issues
Unread post by Toby_HDi »
Got a 405 here 1995 with the XU5 engine (1.6)
Basically it has not been running right. Idling high (what are they supposed to idel at? I always thought about 800rpm?) and not returning to idle on overrun. It would also just lose all power when you went to throttle up.
I discovered a fuel leak in the engine bay which was down to a loose clip. tightened that up and now you can throttle up no problems (still doesn't feel right after driving my HDi :roll:)
The problem of the idle speed and not returning to idle is still present. On top of this the fuel gauge oscillates slowly, going down to between the 1/4 and 1/2 mark and then back up to just above 1/2 (which I believe is what is in there) EM light shows when it wants to, it's not on atm.
I believe some of the problem lies with the throttle cable. The inner cable seems very baggy yet I can find no way of adjusting it.
Any ideas?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
OwenP
Unread post by OwenP »
Can't really help with the high idle, but on my 405 the fuel gauge has a few quirks.
When full it reads optimistic, then it will plumment suddenly to 3/4 and when it reaches 1/2 it will read very pessimistic, bouncing between 1/4 and 1/2 as the fuel sloshes.
Could your gauge be doing something similar to mine?
2001 406 Rapier 2.0 HDi 90 Estate - Sold Scrap after being viciously attacked by a falling tree
2001 Toyota MR2 1.8 VVTi - To be sold for spares/repair - dead gearbox :(
2014 Seat Ibiza Eastate 1.4 FR ACT (bought in an emergency, but a nice enough low mileage car)
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
There may be a couple of issues here, with the engine running check the voltage across the battery to ensure it is stable at just above 14v.
As for the fast idle speed look/listen carefully for an intake leak beyond the throttle butterfly, including any disconnected vacuum hoses.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
