c5 clutch adjustment
sportingfiat
Unread post by sportingfiat »
right nrarly got my c5 back to a1
only niggle i have is when changing gear sometime it crunches as though the clutch could do with tiny bit more movement
how easy are they to adjust??
cheers
andy
AndersDK
Unread post by AndersDK »
Nothing to adjust really, as they are hydraulic activated like a standard brakes system.
The master cylinder is self adjusting just like a brake caliper taking up wear on friction plates.
You might be able to fiddle another 50K mileage out af a worn clucth by DIY shimming the master cylinder.
Provided the fluid level is correct ...
Well worth an overhaul cleaning parts and replacing the fluid.
AFAIR there is a bleed valve on the master cylinder. Try bleed it as any air would eat from clutch pedal travel.
Anders (DK) - '90 BX16Image
sportingfiat
right will try bleeding it, i know it had a new clutch about 10 k miles ago so shouldnt be worn yet
hopefull will be fluid, where is the fluid for the clutch???
still workin my way round the car defo gotta get hold of a manual be a lot easier
cheer
andy
Citroenmad
x 110
Unread post by Citroenmad »
The clutch uses the same fluid as the brakes, might even benefit from renewing that.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
