berlingo 2.0hdi non start
ricster
Unread post by ricster »
Only starts with easy start then runs ok for about 10 miles then engine light comes on and it loses power pulling the codes i have
p 0336 p 0500 p 0704 and p 1198 the last one i cant get a description for any help please
Also if you switch off while running and immediately try to restart it wont without easystart
Any ideas thanks Ric
x 1055
Unread post by wheeler »
P1198 is a fuel pressure related fault. Is it a bosch or siemens system ? Do you have a diagnostic tool that can read the high fuel pressure ? The ECU needs to see about 120 bar before it will even consider starting, My thoughts are most likley an injector fault or the HP fuel pump.
ricster
Reading with my solus i see on cranking delivered fuel pressure of 102 bar and p1198 reads as fuel pressure regulator so is it regulator or pump i am not familiar with Citroen so any help is welcome
Thanks Ric
ricster
ANYBODY :shock:
