Xantia Steering Rack
Toby_HDi
x 3
Unread post by Toby_HDi »
Right, my gaiter is hanging off and I don't trust the garage to do it again. The problem is getting worse and so I think I need to remove the rack and clean it before reassembling with a new gaiter.
As I see it, remove the wheels, track rod ends, disconnect all pipes, remove rack?
I know thats a generalisation but is that it? Are there any pitfalls to this job? Anything that might make it easier to what the BoL suggests?
The BoL also suggests a number of bolts need renewing. Is this so? Any seals that'll need replacing?
Any input appreciated
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
rory_perrett
Unread post by rory_perrett »
That's just about it. Removed my rack over Easter to replace the ram which was leaking. The 2 bolts that hold the rack to the sub-frame require an 18mm socket - a size that often isn't in socket sets. A 19 does seem to fit, but can than slip and knock the corners off the bolt. Must confess I have re-used the bolts.
Remember there is a small plastic hydraulic return pipe on the ram gaiter that needs to be disconnected.
The 2 biggest pains of the job for me was getting the steering shaft coupling off and back on again and manouvering the rack out and back in again, there is very little room.
I found I had to un-bolt the rack in order to get the steering shaft coupling off and had to reconnect it before bolting the rack back down again. This made it impossible to get the steering wheel straight. Resorted to taking the wheel off and repositioning after the tracking had been re-done. Good luck.
Rory
x 1238
Unread post by Peter.N. »
An 11/16" socket is a good fit, if you are as old as me. :D
KennyW
x 163
Unread post by KennyW »
Hi Toby,
I recently replaced my rack after a leaking steering pinion.
I found to remove the rack from the car via the offside, i removed the wishbone and this improved the access.
As you pointed out remove the UV joint from the pinion and replace that first when installing.
Which gaiter is goosed :?:
On my rack it was the nearside gaiter where the bolt for the ram is located and I found it easier to remove the track rod from the rack to replace same.
Otherwise not to hard a job.
Kenny
C3 1.4 petrol (SWMBO)
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Thats an interesting point about removing the rack! HOW!!??
I recently changed a leaking pinion valve on the S1 Xantia TD.. however, tried as I could the damm rack was NOT comming out of the off or near side - the pinion valve was just too tall... I guess removing the wishbone might have helped, but I just could not see how to get it through, twisting or turning it on the way - nope no chance!!
So I just settled for having the pinion right above the wishbone so I could get to the pipe unions, and swapped it through the wheel arch..
Refitting - I reused all bolts and nuts and just tightened them DAMM tight.. if yur not happy with that, put a bit of thread lock on the bolts!
Rgds
Paul
A very sad...
1994 XM 2.1 d auto
rory_perrett
I got the rack out thought the offside without removing anything else other than uncliping the heat shield (sorry forgot that bit earlier). But as Paul says it is an incredibly tight fit took me ages of twisting and turning to get it out. I wish I had taken a photo of the way it was orientated as it came out because it took me just as long (if not longer) trying to get it in the right position so it would go back in again. Whether the engine varient makes any difference I don't know.
Thinking about the bolts, the usual reason for new bolts is when they are in an application where they work in tension and may stretch eg cylinder head bolts. On the rack the torque setting is not that great and they don't really operate in tension, once they've held the rack down the force they have to resist is mostly side to side. You are supposed to fit new nyloc nuts each time and off course we all do don't we.
Rory
Toby_HDi
x 3
Thanks fellas.
I think the main one the BoL states to replace is the UV joint pinch bolt, but from your replies I guess all the bolts can be reused. I have some threadlock anyway.
Will try to get away with not removing the wishbone. Is the heatsheild easy enough? Just a few bolts I assume?
As for the track rods, will I need any special tools (eg. separator tool)?
I see GSF sell the gaiter, do they supply the clips to secure it too? Seems the garage just secured it on with a cable tie (and not too well it seems) but I thought it would use a proper metal band like a CV boot.
Am not really lookinf forward to it as it'll have to be done up on stands in the road :(
I may attempt it this weekend, it's got to be done though.
Toby
Previous:
x 94
Unread post by citronut »
if its the N/S the garage did they may well have fitted it the wrong way round, as one end has a very slight diferance in diamiter, and if fitted the wrong way it will not stay put,, when its the right way round cable ties are fine, unlike a CV gaitor it is not beeing rotated
so check and check again
also i found the rubber GSF gaitor to long, but the OE gaitor is thermo plastic so dose not stretch over the steering ram spigot, as they intend it to be fitted by stripping the rack down
regards malcolm
MikeT
x 232
Unread post by MikeT »
Hi Toby,
Mind if I pop over to observe? Always willing to lend a hand if need be. Not sure I'll be free at the weekend yet but if I am, is that ok?
Toby_HDi
x 3
Of course Mike, no worries at all. TBH an extra pair of hands and eyes could prove helpful.
Toby
Previous:
Pleiades
Unread post by Pleiades »
Hi Toby.
As Malcolm states, if it's the left hand gaiter, you should realy be stripping the rack to fit, otherwise you cannot get it over the spiggot bit that holds the ram on, unless you are going to stretch a rubber gaiter over this, in that case, why not do it this way without removing the rack?
If you do go down the removal route, then personally, I allways remove the pinion from the rack before taking the rack out, as the gap just aint big enough, it will go through with pinion attached but takes a bit of swearing and personal insults about Andre Citroens parentage!!
If you are going to strip the rack to do the job, then just make it easier by removing the pinion in situ.
Once out, the rack is dead simple to strip and put the gaiter on.
Have fun.
Regards
Martin.
Toby_HDi
x 3
Thanks Martin, will look into removing the pinion.
I am removing the rack as I feel there is it possible that muck and stuff has found its way under the gaiter. I want to clean it throughly before refitting the gaiter. It is indeed the nearside gaiter
Toby
Previous:
rory_perrett
The heat shield just clips on - just unclip it and push it up out of the way.
Good luck.
x 94
the heat shieled is held on by a wire clip
regards malcolm
MikeT
x 232
Toby_HDi wrote:Of course Mike, no worries at all. TBH an extra pair of hands and eyes could prove helpful.
So sorry Toby, I couldn't make it over this morning, Dad left his wallet on the bus and asked me to run him around. How did you get on, well I hope?
