Xantia II Estate - Rear window wiper
VertVega
x 13
Unread post by VertVega »
Last weekend my Xantia's rear window wiper stopped working. I have seen it made an attempt to wipe but the movement was like 5 cm and since than it stayed in that position. I checked it at the parking area. With the engine stopped, click sound of the relay can be heard when it's switched on.
I don't use rear window wiper so often. I wonder if they have such a "short" life time :(
Can it be repaired? Has anyone done this job? Any advices?
I hope it is not a "closed box" like the radiator fan motors.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
I take it you have checked the arm securing nut for tightness?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Switch the ignition and wiper on, then repeatedly close the tailgate (not massively hard). Does the wiper arm move at all, again?
VertVega
x 13
-Securing nut is tight.
-I have tried closing tailgate several times while wiper is on. Also gave some additional knocks around the wiper motor area but no change.
Now I know why some Xantias had the rear wiper somewhere in the middle but not in the base position :)
Next I will remove the wiper motor :?
VertVega
x 13
Wiper motor is working again :D
The motor was suffering lack of lubrication and that caused mechanical problem. There were only some remains of a very clean and red colored grease. I think they didn't apply enough amount during manufacture because it can not disappear. It was well sealed and there were no leaks.
I had to remove the wiper motor and open the cover by drilling out the rivets. Cleaned and applied new grease. Repacking needs screws to hold the cover and the body. I used 4 mm screws.
