Steering knock/creak
Toby_HDi
- x 3
Just a quick one...
Anybody have any experience with a kind of knocking/creaking noise coming from the steering wheel/rack?
It only appears to be when turning the wheel to the right and when it gets to a certain point. It's like something isn't greased properly or something is rubbing. I cannot explain it very well.
Am just concerned as since its started I swear the car doesn't feel right. Seems too harsh, knocks on bumps and when coming out of junctions with the wheel turned sometimes it feels like something is vibrating.
Any ideas before I start to investigate?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
citroenxm
- Fallen Hero
- x 70
Rack mounting bolts loose????? Had this on a BX DERV once, thought the rack was buggered, then discovered the bolts were loose, tightened them and all seem better..
I however, have not experianced bolts commin loose on the xantia though...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
- x 1240
VertVega
- x 13
I would guess it could be CV joint. Those unusual clicking noise while turning almost always indicates a worn or damaged outer CV joint.
You can test it by driving slowing in a circle. Than the same test drive in reverse. Keep steering wheel constant (turned to right in your case).
Xsarahdi
Our ZX makes a creaking/knocking/rubbing noise while going around right hand turns and knocks while going over bumps aswell just as you have said yours does Toby. It has been doing it for over a year now and started just after we had a new exhaust and new front right hand tyre. I have just tried to ignore it but it is very annoying making a loud noise nearly every time you turn right
. I haven't bothered to do anything about it yet so it will be interesting what people think it is.
2005 C3 1.6 HDi 110 VTR
2003 Xsara 2.0 HDi 110 SX
1999 306 1.9 TD Meridian
1996 ZX 1.9 D Elation
Toby_HDi
- x 3
As far as I'm aware there is no clicking on full lock. I will have another listen tomorrow.
It only does it when the wheel is turned to the right and it gets to a certain position.
I do hope its not the CV joint
Toby
Previous:
Previous:
VertVega
- x 13
Try to find a smooth surface (parking area) and get that noise by turning the steering while driving in a circle. Then keep the steering position same and reverse drive. If the noise gets even louder than it's definitely the outer CV joint.
At the moment I have the single "clonk" sound effect which is heard rarely while accelerating from traffic lights. That's from the inner CV joint
That's very seldom and I didn't do anything about it yet.
- x 1240
Toby_HDi
- x 3
Ok, just been out and investigated. There is no clicking on full lock that I can hear.
It's more like a groaning/creaking as the wheel is turned, at first I though it was coming from the steering boss but I fear it may actually be coming from the rack. As I say, almost like something is running dry.
Any further ideas?
Any further ideas?
Toby
Previous:
Previous:
- x 1240
Toby_HDi
- x 3
Don't think so.
Without teh engine running, very slightly, barely noticeable. As soon as the engine is running it starts to do it. Only when the wheel is turned right and at a certain point, as it comes round to the straight ahead point. Seems to possibly be coming from the U-joint under the car? Could be wrong. I can't seem to pinpoint it exactly
Toby
Previous:
Previous:
- x 1240
Toby_HDi
- x 3
Only when turning the wheel. And only when turning it to the right. Pretty sure it doesn't occur when turning to the left
Toby
Previous:
Previous:
- x 1240
Toby_HDi
- x 3
I've done this but still cannot pinpoint the exact area. My ears are pretty useless
Is it likely to be that or could it be something else? How easy would it be to replace?
Toby
Previous:
Previous:
