CD Changer not detected on 4030 stereo
red_dwarfers
x 58
Unread post by red_dwarfers »
I've been fitting a Blaupunkt CDC-A03 CD changer to my Xantia this weekend to go along with the 4030 head unit thats in there now. I've fitted the 8 pin miniDIN loom from the boot to the head unit and wired it up using pinouts from the forum and the now deceased steve.jellybaby.net site which I found in PDF form and the following nuggets of info dug out from the forum library :
PDF -
RC and CD Changer C
pin 1 - CDC R
2 - CDC L
3 - CDC ground
4 - U5/REF
5 - A2
6 - A1
7 - RC BEL
8 - RC ground
The cable pinouts should be something like this:
Power Pins A
Pin 1 - N/A
Pin 2 - N/A
Pin 3 - N/A
Pin 4 - 12V
Pin 5 - Automatic aerial
Pin 6 - Illumination
Pin 7 - Ignition
Pin 8 – Ground
The only thing I have not followed is on the PDF link with regards to the 12v ignition switched input which is now connected to the 'official' switched power.
</background information>
After checking the wiring, the head unit fires up as normal and the CD changer does it's seeking for CDs all the way up and back down, it ejects the CD cassette as normal and detects a CD when put in and spins it up for a bit.
The head unit however is being ignorant and not detecting the CD changer, after pressing the MODE button, it goes to find a tape in the deck (which incidentally is broken as it makes an unhealthy noise), press again and it will go to the AUX port if I have a plug in there, press again and it will go back to radio.
I have checked using an Ohm meter that all the wires connect from the boot end, right up until the newly modified ISO plug and all it well.
Any ideas?
Im presuming the head unit detects the CDC by recieving packets from it via the data line on the 'power connector'
Kev
'19 C4 Cactus 130 Flair
Ross_K
x 110
Unread post by Ross_K »
The 4030's the old radio isn't it?
I dunno if this is of help - pinouts for Blaupunkt stuff of a mid-90's vintage:
http://www.michaelneuhaus.de/golf/golf4stecker.htm
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
The CD changer Citroën used on a S1 Xantia was a CDC-A05 so I wonder whether you have the wrong changer.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Is there anywhere that gives an idiots guide on how to fit a CD changer :) :)
I have checked that i dont have the wiring loom for the changer although i can get it from citroen at £115 ish :twisted: :twisted:
I have the 4030 head unit and pretty sure i can get the changer :wink: :wink: but im not sure on the wiring side of things :oops:
DickieG how sure are you on the CDC-A05 being the correct one :) :)
Colin
DickieG
x 33
admiral51 wrote:DickieG how sure are you on the CDC-A05 being the correct one :) :)
I still have the box for the CD changer I bought from a dealer when XAN71A was new.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
admiral51
(Donor 2026)
x 391
Thanks DickieG sorry to distrust you :) :)
Have done a little bit of digging for some info on the net
Blaupunkt site has some good info catalogue pdf file :wink:
Blaupunkt vehicle specific information vehicle check sheet
Colin
x 1460
Unread post by xantia_v6 »
I can confirm that the original was CDC-A05, but I have changed the CD changer a couple of times due to hardware failures, and at least one of the replacements was a different model number from a mid-90s BMW. I think any Blaupunkt changer from that era should work (but reportedly, some newer Blaupunkt changers will not).
I think I posted the adapter lead connections here a few years ago.
red_dwarfers
x 58
Thanks lads and lasses
Xantia V6,
what model changer do you have in yours at the moment?
Kev
