Fitting the mudflaps...
davetherave
- x 4
Well im probably just being stupid, but the instructions to fit the mudflaps i just bought are not great, and i dont think they will be that secure screwed into the arch plastic, anone got any advice on fitting them? cheers
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
GPZ500s
dnsey
- x 19
davetherave
- x 4
mop
vince
- x 13
Dave, if these are for your Xantia, then there are special Citroen brackets to fit them. Yes you can fit them with screws but they ideally need at least 2 OE clips per flap to keep secure, you can add extra screws if you feel it necessary.
Also if for the Xantia, if you have fitted bigger tyres than standard they can rub on full lock on the front flaps only. To solve this remove the centre OE mudflap bracket / clip and just secure with one at the top and one at the bottom, they are secure enough like that, rubbing solved
davetherave
- x 4
