Hi, the door mirrors on my Xant don't seem to be adjustable laterally via the door switch. I can adjust them up/down but not left/right. This is the same for both sides so I am suspecting the switch itself. What is the easiest/best way to get the little blighter off the door card?
Cheers
Leccy Door Mirror
citroenxm
- Fallen Hero
- x 70
Hi..
Were the Door handle goes up and under the plastic part housing the Door switches, if you look under there were the handle goes up you'll see a tiny 9mm TORX screw...
Undo the Torx screw and the plastic part housing the door switches and mirror switch comes away leaving the door opening lever in place and the door handle...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Penguin
