Towbar Fitting
Xantic
x 11
Towbar Fitting
Unread post by Xantic »
Is it an easy job fitting a towbar on my 1999 Xantia hatchback.
Does the bumper need to be cut.
Wheres the cheapest place to buy a towbar, Unless someone has one for sale..
Thanks.
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
x 8389
Fitting a towbar is dead easy :D A Witter goes on without any cutting whatsoever. Back bumper off and bolt it on. Even the holes are there for you and a blind grommet ready to take the electrics :D The Electrics are pretty straightforward too and it can be very neatly hidden behind one of the boot side panels.
the only tricky bit will be providing a high current feed if you intend fitting a 12S socket to run a caravan fridge and so on. getting a thick wire from the battery through the bulkhead is not straightforward.
A Xantia Estate is even easier, so long as you ignore the BoL procedure to remove the rear bumper as it's totally WRONG!!!
Xantic
x 11
It will only be for a small camping trailer..
Sounds ok, now to find the best price towbar..
Russ..
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
reblack68
Unread post by reblack68 »
Towequipe are pretty cheap, and they are doing a Xantia wiring kit for £15.
http://www.towequipe.co.uk/categorylist ... ed-towbar/
The hardest bit for me was removing the bumper. The captive nut on one of the sides escaped and it was a real pain to refit the bumper. I had to make a small cut, maybe 2" square in the bottom of the bumper.
Richard
Care of a 1994 205 D.
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
agree with Jim and Richard re their bumper thoughts...
I just couldn't get my bumper off due to captive nut problems...
I did get the towbar on..spare wheel cradle dropped and rear exhaust can removed... but its damn heavy (witter) working alone with it above you and the bumper getting in the way, especially outdoors on a cold winters night..
I had to fit it (needed next morning to move a v6 engine around the farm :D ) nothing like being prepared hey ..
:D
reblack68
I think I ripped the spinning captive nut out of my bumper, the hard bit was holding the replacement nut and washer in place while I bolted it back on.
Richard
Gregg1100
x 5
Towbar Fitting
Unread post by Gregg1100 »
Try Towsure
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
Xantic
x 11
All this talk about bumpers not wanting to come off is making me nervous..
Never mind Mr.Carling im on the Guinness..
I said im on the Guiness.. :D
I thought i would double post in the one post..
Make it easier to read.. :)
Thanks for the info i shall let you all know how i get on...
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
reblack68
I cheated with that one. I plugged a spade connector into the fuse position for heated seats, with an inline fuse on my cable. The feed for the heated seats should be good for 40A (that's the fuse they would have) and my 12S kit came with a 25A fuse so I reckon the wiring is up to the job. Obviously that option is only available if your car isn't equipped with heated seats.
Richard
Stempy
Unread post by Stempy »
Well I guess you could spur off the heated seat loom as long as you don't use the seats with the fridge on :wink: You could also possibly fit a change over switch so that only one spur could be used at a time.
There are a couple of used towbars on fleabay at the mo, item 130302346112 is one, but I guess you'd have to live nearby for that one.
Lexia ponce
Xantic
x 11
Are there any make of towbars that i could buy without the need of removing the rear bumper to fit.
I like making my life easier... :)
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
Ross_K
x 110
Unread post by Ross_K »
I don't think so. The bumper support in the middle needs to come out to make way for the towbar to bolt on from what I remember...
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I used to run a 2.1 Xantia estate and fitted a towbar with twin electrics to it and I didn't have to remove the rear bumper. Got it from Towsure.
2010 C5 X7 VTR+Nav 160
1998 1.5 Saxo
1998 Pug 306 1.9D
2018 C4 B7 VTR+
2011 Citroen C1
Koukku
x 8
Unread post by Koukku »
The bumper and towbar fittings on an estate are totally different from the saloon. I.e. on a saloon the bumper needs to be removed. I just removed a towbar from my Activa, and there's no way to reach all the bolts with the bumper in place.
- Previously Activated -
Xantic
x 11
Thanks for the info everyone..
Looking forward to removing the bumper then,When i buy a towbar that is..
:lol:
Russ..
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
