xantia estate rear suspension hard?
rummins 123
Unread post by rummins 123 »
hi my p reg xantia has over the last few weeks has for some reason got very hard on the rear especially when i go over those dreded speed bumps and the car is bouncing from the rear .
i know the spheres go but would this only happen on the rear like this and if so are they hard to change or could it be something else ?
Martycit
Unread post by Martycit »
Its got to be the spheres mate, mine are also due soon on my estate and the car tends to rise slower than it should on a morning. Ive had a few xantias and the results are great when you do change them.
FrenchLeave
Unread post by FrenchLeave »
Bear in mind that when the suspension is in "Sport" mode it is quite hard. The difference between "Sport" and "Normal" is the centre (hydractive) sphere, so if money is tight try just changing that one.
They're not too difficult to change; car on ramps and you'll need a chain wrench or something similar to slacken the old one. Don't forget to exhaust all pressure before you start (suspension on low). Check the old seal has come out with the sphere, fit new seal to new sphere, coat mating surface with LHM and screw the sphere in hand tight only. Avoid the temptation to nip it up with the chain wrench!
Derek
1999 XM V6 Exclusive, Black
1994 XM 2.0 TurboCT estate, green of course: now gone to no3 son
2004 C3 1.6 auto exclusive with Sensodrive - the wife's but she doesn't like it
1994 ZX 1.8i auto - the wife's new baby
red_dwarfers
x 58
Unread post by red_dwarfers »
rummins 123
Is your Xantia a VSX or Exclusive?
FrenchLeave wrote:Bear in mind that when the suspension is in "Sport" mode it is quite hard. The difference between "Sport" and "Normal" is the centre (hydractive) sphere, so if money is tight try just changing that one.
Derek
If so, the above won't apply.
Before you go changing the spheres, check the height of the rear of the car, the wheel arches should be roughly level with the top of the tyre give or take an inch or 2. If it is riding too high or low, your height corrector LINKAGE will need a good soak in WD 40. More details can be found by running a search on the forum :wink:
Kev
'19 C4 Cactus 130 Flair
rummins 123
hi its a vsx if that helps ,and i didnt know there was sports and normal suspension how do i change between modes ?
red_dwarfers
x 58
rummins 123 wrote:hi its a vsx if that helps ,and i didnt know there was sports and normal suspension how do i change between modes ?
On the VSX which has Hydractive suspension, there will be a button just forward of the height control lever.
Kev
FrenchLeave
I'm sorry if I've misled you. I'm an XM man and I assumed that Xantias were fitted with hydractive, serves me right for sticking my nose in where it's not wanted. My advice about sphere changes in general is still valid.
Ref the height linkage tip from red-dwarfers, it is always sensible to ensure the linkage is free and lubricated but I can't see how ride height will affect ride comfort - unless it's so low as to be near the bump stops.
Derek
red_dwarfers
x 58
FrenchLeave wrote:I'm sorry if I've misled you. I'm an XM man and I assumed that Xantias were fitted with hydractive, serves me right for sticking my nose in where it's not wanted. My advice about sphere changes in general is still valid.
Derek
Don't fret about it Derek, we all learn something new everyday :D
On the Xantias, im not sure on the XMs :wink:, if the spring linkage siezes, that end of the car will generally only settle at service high or low, before it does this it can be made to go to normal drive with a bit of jiggery pokey :lol:
Kev
Xaccers
x 188
Unread post by Xaccers »
If the height corrector isn't doing it's job and getting stuck a bit high, the ride will be harder, just as if you move the manual adjuster to the slightly above normal setting, the ride is much harder but you still have a bit of suspension compaired with the max setting.
DIY sphere tool
rummins 123
ok thanks all for the replys now i have something to checkout cheers
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
FrenchLeave wrote:Ref the height linkage tip from red-dwarfers, it is always sensible to ensure the linkage is free and lubricated but I can't see how ride height will affect ride comfort - unless it's so low as to be near the bump stops.
Ride height is quite critical for a smooth ride, for instance on my estate it was no more then 1" too low at the rear which had quite a detrimental effect on ride quality when I bought it.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
