Xantia washer bottle.
lexi
x 133
Unread post by lexi »
My windscreen washer wont operate. It on the 1.9td estate. I have checked that power is there at the feed to the little pump on the bottle.
Assuming that pump has failed can we get a pump from Citroen or is it the whole bottle assembly? Do GSF do any kit? Awkward sod to get into.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
newmezuk04
Unread post by newmezuk04 »
If its the little pump it may be cheaper to salvage one from a scrap yard.
x 8391
I think I'm right in saying the pump has two output spigots on it and one feeds the windscreen washers and the other goes to the tailgate jet. The motor spins one way for the windscreen and the other for the tailgate.
The pipe to the windscreen gas a one-way valve in it under the O/S/F front wing liner. If this valve develops a fault, the pump will spin but no water will reach the screen.
lexi
x 133
I`ll pull the hoses off and look at it. Even with a blockage would it not make buzzing noise as it tries to pump? Mine is silent. It`s usually the case when I find a Xantia in breakers it is on the ground and no room to get into bottle.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Stempy
Unread post by Stempy »
Try ebay item 280336145564, I've also seen them in Halfrauds.
Lexia ponce
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
GSF A Tenner!!! BRAND NEW!!!
Paul
A very sad...
1994 XM 2.1 d auto
lexi
x 133
That will do for me!
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
