Hi guys, ive got an idea on this one but wanted to share your experiences to check for any other causes...
1996 Xantia TD. When parked overnight, or all day at work, i.e for a time longer than a couple of hours or so, when the car is started it chugs into life is the best way i can descibe it. Plenty smoke too out the back which im guessing is unburnt fuel.
Ive tried leaving turning the key for longer after the glow plug light goes out but it doesnt seem to make any difference. Neither does increasing the revs after starting and keeping them level.
Im thinking duff glow plug(s) due to smoke and the chugging which feels like a cylinder isnt joining in the party straight away.
The problem with this assumption though is that the engine would be just as cold if left for two or three hours or if only a short trip was done then left for a short time, but it starts on the button then with no problems.
One extra thing which has just occured to me is it seems to have gotten worse since doing daily motorway trips using the car for work....
The only known fault engine wise is a very leaky valve cover gasket and a pipe which comes from down below somewhere and leads into the front facing side of the valve (looks like a breather hose)? which may have a split in it.
Thoughts guys?
Vince
Cold start query...
vince
- x 13
Cold start query...
jgra1
- (Donor 2021)
- x 36
- x 94
yep im with John on this one GLOW PLUGS first, leaky cam cover will not affect the engine running unless it is loosing serious amounts of oil, the only thing will do is make a mess, it is a fairly simple job to replace the cover seal/gasket, the breather pipe is a bit fiddly,
might just as well make job of it whilst doing the glow plugs as your half way there, to doing the cover seal at the same time
regards malcolm
regards malcolm
vince
- x 13
Awesome thanks guys,
Anyone near Oldham fancy giving me a hand...aka showing me how to do it
If not then i will book it into Paris Autos next month when i get paid...
And Citronut, the valve cover has made a right mess of the engine, the sump is covered in sludge...aka burnt oil residue.
Never mind for now, its off to jolly Liverpool again in the morning....I must admit, the car is a joy overall to own and drive
