The speedo on our ZX occasionally doesn't give any reading, but on the next startup it works fine. According to Haynes it has a mechanical drive with the cable break point in the engine bay on the left hand side of the scuttle.
Every instinct about its behaviour tells me it's electrical, when working the needle is smooth and steady and the total on/off behaviour is not compatible with cable drive. Also there is no sign of a speedo cable entering the left side of the scuttle - or anywhere else for that matter.
Could the experts please confirm whether it's mechanical or electric and if it is electric, where the auto gearbox drive and cable connectors are. At 76 years old I don't want to dive under the car until I know what I'm looking for.
I can dismantle the instrument panel on my XMs inside a half hour but for some reason I'm not happy about the ZX!
Thanks in advance,
Derek
1997 ZX speedometer
FrenchLeave
1997 ZX speedometer
1999 XM V6 Exclusive, Black
1994 XM 2.0 TurboCT estate, green of course: now gone to no3 son
2004 C3 1.6 auto exclusive with Sensodrive - the wife's but she doesn't like it
1994 ZX 1.8i auto - the wife's new baby
- x 94
if it is an electronic speedo, you will find the a unit (transducer) with a plug conector were a speedo cable would normaly fit into the top of the diff houseing, this type usualy suffer with bad conection's at the plug, the easyest fix is remove the transducer from the diff houseing, clean the terminals, grease them and re/fit it,
if you have flexable wrists you should be able to do get to it from under the bonnet as it is just at the rear of the head/block gear box end of engine
regards malcolm
regards malcolm
- x 1238
FrenchLeave
Thank you Malcolm, I'll see what I can find tomorrow.
Yes Peter, I've registered. I've also posted on Assiefrogs (I'm a tadpole!) to let Craig, Shane and anyone else interested know about Ciaran's sterling efforts.
Derek
Derek
uncle buck
- x 10
- x 1238
