Has anyone replaced there Xantia saloon rear disc & caliper with ones from an estate? Do they fit? (They have alot bigger disc, pad & piston.)
http://www.citroen.car-brakes.co.uk/ (A site I found, not used them but has very useful info.)
Xantia Rear Brakes
SLYTZD
Xantia Rear Brakes
Simon
'96 Xantia Activa in Silver 95,000
rory_perrett
I would question why you would want to. While it might not be the case with this change, a car that is "over braked" on the rear can be dangerous. Locking up the rears before the fronts could cause the car to go into sudden over-steer, not nice. OK so the ABS should sort it out and prevent this from happening but its not really good engineering to rely on clever electronics to sort out bad mechanics.
reblack68
DickieG
- Monaco's youngest playboy
- x 33
I'll second that as my old C15d's had a tendency to do that, one of the best laxatives known to manrory_perrett wrote:I would question why you would want to. While it might not be the case with this change, a car that is "over braked" on the rear can be dangerous. Locking up the rears before the fronts could cause the car to go into sudden over-steer, not nice.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
SLYTZD
Rear Brake Upgrade
The reason for asking is there's a lot of talk on the forums about up rating the front brakes with better performance discs & pads. I’ve read posts saying that the V6 callipers are almost twice as big & will bolt straight on to the front (with new discs) as the Xantia does suffer from brake fade if you drive it hard on stock parts. Nothing's ever mentioned about upgrading the rears though. My thought was not just to up rate the rear because as you say it could upset the brake balance but up rate both. The estate version is approximately 45kg heavier on the rear. I semi-regularly tow with my Activa & it was an idea I was toying with.
Simon
Xaccers
- x 188
I think the only time I've had brake fade from my estate is when the pads are really really low, and I use Milton Keynes as a rally course
DIY sphere tool
DIY sphere tool
Koukku
- x 8
That's an interesting idea. V6 is about 50kg heavier than TCT on the front, and estate is 45kg heavier on the rear, so it should not upset the brake balance of a TCT.
On a V6 the estate rear brakes might upset the balance, but I wonder if it would really make a difference. After all, the rear brakes take their pressure from the rear suspension, so the estate rear brakes fitted on a saloon would not brake as hard as they do on an estate...
- Previously Activated -
