I'm having an intermittent problem with the gear select lever lock on the V6 in that it doesn't always release. I've fitted a new brake pedal switch and cleaned the electrical plugs and sockets that I can see.
The plunger on the solenoid seems free enough so I was wondering if one of you splendid chappies with access to wiring diagrams could tell me what else might be in between the brake pedal and the solenoid. When it fails to throw I can hear a relay clicking somewhere when the pedal is pressed, but I have no idea if that is part of the circuit or indeed where it might be.
Autobox gear select lever lock
Stempy
Lexia ponce
Lexia ponce
- x 8386
Stempy
It's a Mk2 Jim, thanks..
Looking at that diagram, if 1638 is the solenoid then it would be worth checking relay 1642, just have to find it
Lexia ponce
Lexia ponce
- x 8386
Hi Stempy,
Again, this is for the MK1 but this Location Diagram might offer up a clue.
I'll get the MK2-specific diagrams up this evening...
- x 1459
My Mk1 V6 had a problem last christmas, where the solenoid was not being energised, and when manually unlocked, the transmission would start in 3rd gear. It cured itself after a week and has not done it since, but the symptoms are of a faulty selector switch on the transmission (probably metalic dust bridging the contacts).
- x 8386
- x 1459
No there were no warning lights. The probem is leakage across the switch contacts connected to pin 4 of the connector ( the right hand bank of bank of component 1600 on the page 112 diagram).
The ECU sees valid combination from the switch, just not the correct one for the lever position. The effect is that when lever is at P the ECU thinks it is in the intermediate position between P and R (and the lever lock is enabled), or when the lever is at D, the ECU thinks that it is in the intermediate position between D and 3 (which prevents normal changes).
I think that the Mk2 has a fuse that can cause similar symtoms. See the december thread.
Stempy
So I had a poke around today, and using a combination of the location diagram, listening and feeling I found the relay in question. Now, although I have a plethora of spare relays, sods law dictated that I haven't got one of this type, but as it happens, located right next to it is an identical relay, so I swapped them over and hey presto, problem solved.
Now I have no idea what the other relay does, so now I'm waiting to see what else has become intermittent. The relay is sealed so I can't pop the top off to clean the contacts without breaking it. It's rated at 25A and has a fixing tang extending from the top, is grey in colour and is located in the drivers footwell under the felt trim behind the fuse box hinge, anyone have any ideas?
Lexia ponce
Lexia ponce
- x 8386
addo
- Sara Watson's Stalker
- x 95
Stempy
Well I guess one way to find out is pull it out and see what doesn't work
Lexia ponce
Lexia ponce
