Berlingo 2.0 diesel 2001 HDI powerloss
mickeybo
Unread post by mickeybo »
engine code rhy bosch system on checking wastegate solonoid valve
found ignition on voltage at this valve only 3.55 volts and same voltage
at egr solonoid 3.55 volts plus same voltage at 3rd piston cut off
according to auto data wiring diagram these units are feed from 15 pin
relay no 5 pin on this relay i find this information incorrect as there
is no connection for pin 5 at multi-plug any one know where aperson
can locate wiring diagram or shed some light on this any feed back
greatly accepted reguards paul :roll:
x 1052
Unread post by wheeler »
Should be pin 4 of the 15 pin double relay, the wire number is 120.
