C5 GPS antenna location
dnsey
x 19
Unread post by dnsey »
Does anyone know where the antenna for the factory-fitted GPS system is on the early C5?
I discovered the other day (should have realised before) that the athermic windscreen blocks the signal for my satnav, and I'm wondering where an external antenna will have the best view of the sky, preferably without drilling a hole in the roof!
Ross_K
x 110
Unread post by Ross_K »
It's in the aerial base over the back window, no?
x 1052
Unread post by wheeler »
Yes the factory fit one is in the normal areial base. The two black shaded areas on the windscreen at either side of the rear view mirror are non athermic for the fitment of road toll tags etc. these areas are also ideal for GPS aerials, the cable can be routed neatly along the headlinings & down the A pillars.
dnsey
x 19
Thanks very much, gentlemen, just what I needed
mop
Unread post by mop »
I have a TOMTOm 730 which I hold out the window which gets a fix real quick (under 10 sec) and it works fine after that with it's internal gps. I have it located botom right on the dashboard.
05 C5
