Xantia Folding Rear Seats
hilldweller
Unread post by hilldweller »
Hi All,
I have a 98 Xantia estate (1.9td) but unfortunately it didn't come with a handbook.
I could do with putting the back seats down to fetch some furniture in it, but the bit you sit on doesn't seem to come forwards very far. Should it? I don't want to yank it and break it. :D
Ta
John
Citroenmad
x 110
Unread post by Citroenmad »
Do you not have to lift up the front of the seat base and pull that up slightly, then it should lift up all of the way, so you can fold the rear of the seat behind it.
Chris.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Xaccers
x 185
Unread post by Xaccers »
Lift the front edge of the bit you sit on straight up, then pull the back edge up and forward to rotate the seat forwards.
Then you can drop the seatbacks down.
It helps to move the front seats forward a bit, and also remove the rear headrests.
DIY sphere tool
hilldweller
Aha! Yes that did the trick, I wasn't lifting the front up. :oops:
Thanks chaps!
vince
x 13
Unread post by vince »
Xac, how do you take the rear headrests out? mine seem welded in :cry: Ive looked for buttons to push etc but no luck.
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
vince wrote:Xac, how do you take the rear headrests out? mine seem welded in :cry: Ive looked for buttons to push etc but no luck.
Press/squeeze the button on one of the bases.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Examine the plastic collars pressed into the seat cushion fabric, that surround your headrest rods. There's a small tab on one of each pair, that you push sideways to release the catch pawl.
Cheers, Adam.
