what do we think of this?
mrlogik
c5 hdi 110 lx
Xantia hdi forte 140,000 [sold]
Stempy
Sounds interesting but couldn't see a price. Personally, if I bought something like this I'd like to see it working, I think I'd be a bit wary, especially as the disks look to be copies and are located in Hong Kong. I'd love to have one to play with though so can understand the temptation.
Lexia ponce
Lexia ponce
- x 8389
Deanxm
- x 87
I found a site the other day that was doing a Lexia for half price, around £500, does this sound right? and do they work well for older PSA stuff with the old 2pin green diag socket?
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
- x 8389
£500 is about the going rate for for a good, fully loaded Lexia 2 if you can find one and they're the best for the older stuff.Deanxm wrote:I and do they work well for older PSA stuff with the old 2pin green diag socket?
The Lexia 3 as shown in the link will do them but I believe not fully and you'll need to buy adaptors separately. The one above comes, by the looks of it, with only a 16 pin EOBD-style pulg and for pre '98 Citroens you'll need the 30 pin diagnsostic socket adaptor. An enquiry needs to be made to see if they can supply and at what price.
Deanxm
- x 87
http://www.alibaba.com/product/asmandat ... xia_2.html
Sound like a really nice bit of kit but i dont think swmbo would let me spend £500 just now considering i only have the one car it's not going to get much use................................i need to buy another car thats the answer
Am i right in thinking they can read and clear all onboard ecu's not just the engine management ?
[/quote]
[/quote]
XM Prestige PRV6 92
- x 8389
Deanxm
- x 87
Damn that is tempting
Citroen once told me that the Hydractive ecu could not be read
i did try to argue at the time but when there is three of them stood there shaking heads.........................
XM Prestige PRV6 92
- x 8389
The Hydractive ECU is THE most important one to read Dean - certainly it records more faults than any of the others.
Show me a hydractive ECU and I'll show you a steering position sensor fault recorded in it
The thing with the Hydractive ECU is that any recorded faults in it seem to make it use default values and ignore the sensor in question which, particularly on the Activa, takes the sharp edge off the handling. A regular Lexia session on an Activa is therefore almost an essential part of routine maintenance!
Deanxm
- x 87
DickieG
- Monaco's youngest playboy
- x 33
You don't need a Lexia for the old two pin socket, a simple Gunsons/LED flash code reader will do for thoseDeanxm wrote:I found a site the other day that was doing a Lexia for half price, around £500, does this sound right? and do they work well for older PSA stuff with the old 2pin green diag socket?
D
Is your XM fitted with Hydractive 1 or 2? The reason I ask is that does the first version even have an ECU to read codes from?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
Deanxm
- x 87
Mine is hydractive 1 and the ecu is a H3 from memory, all hydractive cars had computer control for the suspension.
I have actualy got the gunsons code reader, the trouble i have with it though is it seems to be a touch inacurate, i have had mine for 5 yrs and the only codes i have ever got from it are either no fault dispite the orange light of death glowing away furiously on the dash or 'lambda control' which could be anything from the ecu to the sensor itself, and i have never been able to get any codes from the hydractive ecu, i think my ecu can be made to blink the codes via the warning on the dash but even if i did succeed i believe a lexia can perform all sorts of amazing things like firing injectors and operating other components and realtime data from any of the EManagement sensors, i also hear you can adjust the ignition timing and idle speed etc etc, but i may be wrong.
I have seen on a forum (cant remember which one) that you can perform adv or rtard of the ignition timing with the gunsons reader by using the switch to enter codes to the ecu, but it does sound a dodgy way of doing things considering there is no screen to see whats happening.
D
D
XM Prestige PRV6 92
- x 1052
I know with lexia you can definitely adjust the ignition timing on the 1.0 AX's with monopoint injection but i dont know if you can do it with any other engines/injection systems. I cant say i've noticed any option to adjust the idle speed though.Deanxm wrote:i also hear you can adjust the ignition timing and idle speed etc etc, but i may be wrong.
I would say anything with the 2 pin diagnostic connector is more suited to an ELIT diagnostic tool.
Sl4yer
JamesQB
- x 5
I've got a OBDII reader that works alongside a laptop. Our C3 diesel is a 2003 so isn't OBDII compliant but has the 16-pin connector that looks identical to the OBDII ones. Don't know much about it, so wondered if the difference is just the pin configuration so that with a bit of rewiring, the reader would work, or if it goes beyond simple pinouts?
Honda Civic 2.2 CDTi 2006
Peugeot 407 2.0 HDi 2007
