However to re-programme the BSi, Lexia asked for a five digit code (not the one on the immobilser code card as that is only four digits). Would anyone be able to help with where that code is recorded, is it a case of contacting a dealer and paying out £15 for each car or will it be recorded somewhere on the car, service documents or part of the chassis number etc. I take the code will be made up entirely of numbers not letters as the asterisks didn't change when I attempted to enter random codes.
Re-programming a BSi from a Lexia
DickieG
- Monaco's youngest playboy
- x 38
A good friend of mine has a Xsara 2 HDi to which he'd like to add cruise control. I ran my Lexia on it yesterday with the idea of re-programming the BSi and adding the cruise control stalk, when I went into the BSI unit my eyes popped out
at the huge number of options available to turn on/off useful/not so useful facilities on the car simply by a pressing a few buttons on the Lexia.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1044
The code you need is 01134, It's the same on all Lexia's. You also need to go into the injection ECU & set the option RVV to present. Have you also fitted the extra brake switch & does it have a clutch switch ?
Just be aware you cant do it with all xsaras, some dont have the neccisary clutch/brake switch wiring at the ECU. Tried to do it a few years ago with my mates 2002 90bhp siemens xsara & it wasnt fully pre wired up.
A lot of the BSI options wont work if you turn them on unless there are certain components/ECU's fitted that the feature needs. ie the cruise control wont work without the stalk, brake & clutch switches.
DickieG
- x 38
Excellent thanks for that
I'll take a look for the brake and clutch switches, but bearing in mind that the car has the same ecu as you mates car maybe it won't work, no harm in trying though.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
- x 1044
steelcityuk
Sorry to break into this thread but it occured to me the other day that the cruise control on my HDi (C5) only works in 4th and 5th. Whereas on the old XM it also worked in third which was handy on 30 MPH roads. 30 in forth gear on the HDi is a bit too low in the rev range (about 1000rpm I think). I wonder if it's possible to change the cruise control so it is available in 3rd gear? I've been that busy this last 2 weeks this is the first chance I've had to check the forums.
Any idea Wheeler?
Thanks.
Steve.
Any idea Wheeler?
Thanks.
Steve.
not applicable
- x 1044
KevMayer
Hello chaps,
Just a bit of info..
The cruise control on my 2.2 Hdi C5 works in 3rd gear.
But it doesn't work below around 25 mph.
A friend of mine had a Peugeot 307 and that wouldn't work in 3rd gear.
Cheers, Kev
steelcityuk
xmexclusive
Hi Steve
Not all 2.5 XM's with electronic cruise are the same. They started off production with a 30mph minimum setable speed. Mid 96 I think Citroen changed the hard coded programme in the ECU to work down to 25mph. My collection of different 2.5 EPROMs still grows. I day I will sit down and download the EPROMs to find the coding differences. Anyone throwing out XM ECU's throw them my way please.
John
John
Xmexclusive
