I'm posting this on behalf of Toby as he's probably just starting his shift now.
His fans are working half speed all the time the engine is running. Any pointers on how this might be and what is needed to be tested/checked?
Xantia HDi Cooling fans contstantly running half speeed
MikeT
- x 232
citroenxm
- Fallen Hero
- x 70
Mike,
Is his Air COn ALSO running at the same time EVEN With the switch OFF?? Ive a HDi dooing this, Air Con on with fans, but dash switch off..
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Clogzz
- x 40
citroenxm
- Fallen Hero
- x 70
I realise the fans will always run when the system is SWITCHED on, but not with the switch in the OFF, and I mean the Air Con main switch, next to the hazards..
What are you saying? That Window demist slider OVERRIDES the Air con switch weither its switched on ro off???
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
Clogzz
- x 40
Yes, the slider set to demist the windscreen overrides the air conditioning switch:
http://www.frenchcarforum.co.uk/forum/v ... hp?t=24418
2002 C5 2.0i AL4 239,000 km 76372389
MikeT
- x 232
I did suspect the AC was running as I could see movement in the sight glass but Toby assured me the switch was off and as a quick guess/experiment, I disconnected the receiver/dryer which made no difference to the fans or the sight glass view.
I didn't think to check the demist position but I'm sure Toby can answer that later.
Toby_HDi
- x 3
It seems very strange but it is the case indeed.
A quick trip out to experiment shows the fans running constantly with air con switch OFF and the airflow set to windscreen.
On moving the slider across, the fans cut out. I do usually have the airflow set to windscreen most of the time
Thanks for that Malcolm and thank you Mike for posting this thread.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Previous:
jmd
Thanks Clogzz & Tobi_HDi, for that piece of information. Like MikeT - I had an anxious few weeks concerned because my fans were running all the time, found (as a result of reading this) that my problem was the heater switch set to demist. Changed the switch position and all is fine. I have mentioned this to a few machanics, who were not aware of this. The Forum is a great place.
