Testing Radiators
xmexclusive
Testing Radiators
Unread post by xmexclusive »
Hi All
Have some recovered radiators to check out. Anyone know what sort of pressure to take them up to. I was thinking about 15 or 20 psi.
John (Clubxm refugee)
Xmexclusive
broyty
Unread post by broyty »
Hi John welcome over here
Yes 15-20 psi will be ok to test the rads
Mick
1995 cit xm 2.0l turbo exclusive hatch auto
1998 cit xantia 1.9 td exclusive estate auto
1966 lincoln continental 2 door 462 ci
1969 chevy impala 4 door ht sport 350 ci
xmexclusive
Hi Broyty
Thanks, will have a try tomorrow using a foot pump as I suspect that a compressor will not give fine enough pressure control.
John
Xmexclusive
x 1240
Unread post by Peter.N. »
Hello John, fancy seeing you here! :D
xmexclusive
Hi Peter
Hope you had a good time in the far North.
Hi All
The air test worked fine but the small rads were not so good as it took eight leakers to find the one good one that I used. At this rate I will soon have a batch of ten for recoring. Anyone recommend firms for recoring? Is it economic anyway?
John
An interest in 2.5 XM's
Xmexclusive
