I saw this on fleabay-- Item number: 120400920603 and thought it was wrongly described. I thought all the 16v petrols and 1.9 TD's had a PULL type clutch---having fitted one, I know the kit---but this one is a PUSH type, albeit without the thrust bearing. The thrust bearing on the Pull type is fixed to the clutch cover/ pressure plate.
I think a push type can probably be fitted, as long as the push type fork is used-correct me if I am wrong.
Thanks,
Greg
CITROEN XANTIA 1.9TD TURBO DIESEL 215MM CLUTCH KIT BNIB
Gregg1100
- x 5
90 Kawa EN 500 A1- was running---now dead again
04 Kawa GPZ 500 E10 -alive and well.
54 Fiat Punto 1.2 Dynamic
Old Xantias- 16v 2litre 1997 VSX, 2 x 1993 TD Lx, S2 SX 1.9TD
Old Bx's--3 x 1.9 D, 1x 1.6 Auto, 1 x 1.9 GTi, 1 x 1.9 TZS
falling-out-with-my-car
- x 25
doesn't the clutch cable pull against the lever which pushes against the clutch diaphram spring plate? I thought most clutches worked like this?
regards nigel.
regards nigel.
citroenxm
- Fallen Hero
- x 70
Yea, the Pull type clutch arrangement actually MOVES the outer cable forwards when you press the pedal and pulling the release forks outwards - Rather then pulling the inner cable into the outer and pushing the release forks...
I have often wondered if a push clutch would work satisfactorly, with modifying the cable cradle...
Im in need of a clutch for the 1.9td 208k car I got it, its VERY heavy and on the slipping side of its life...
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
