Threads and taps
MikeT
x 232
Threads and taps
Unread post by MikeT »
Anyone know what tap size I need for Toby's rear brake shield?
x 94
Unread post by citronut »
i think the are M6 as they are 10mm sppaner, not sure what pitch they are though, 11mm sppaner size is M7 thread
regards malcolm
x 8378
M6 sounds right and pitch will be 1mm...
Toby_HDi
x 3
Unread post by Toby_HDi »
Aha, thank you Mike.
I had looked at Service Citroen and found the size of the original bolt.
M6x16mm with a 1.00mm thread pitch
Have been searching in the garage for a tap but think its a lost cause in there :oops:
Did you say you had a tap and die set?
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
x 94
Mike i have in the past just drilled out the sheared off bolt remains, and used a 10mm nut and bolt to fit it back with
trhatfds malcolm
Toby_HDi
x 3
Malcolm, the problem is there is some of the bolt that refuses to come out. We have drilled most of it out but there is some left in there and so thinking the best course of action is a rethread.
Toby
Previous:
x 94
just drill it out slightly bigger as its not a crucial componant, precise acuracy is not required,
regards malcolm
MikeT
x 232
Thanks for the thread size and pitch - I do have that size tap. Toby did drill most of it out but I didn't want it going too large to preserve the hole size - might as well keep it original if possible, is my reasoning. I did consider the nut and bolt strategy and will use it if the tapping doesn't work out so at least we have a fall back.
Toby, when's convenient for me to come over?
Toby_HDi
x 3
Indeed, if all else fails then nut and bolt it is.
Any morning is good Mike. Though would need to finish up around 12 for me to get to work. Work all day Saturday (7-6 :shock:) But should be free Sunday or Monday again.
Whichever suits you Mike....
Will try to find some bolts the correct size from somewhere
Toby
Previous:
MikeT
x 232
Is tomorrow morning too soon?
Toby_HDi
x 3
Depending on if I can find some bolts for then. Am going to look at the local surplus stores but don't hold out much hope.
There's not a lot in the way of places that sell fasteners in Ringwood.
I will let you know Mike
Toby
Previous:
x 94
hasn't Mike got any bolts left over from when he had his engine in bits, i have buckets of bolts (no not from customers cars TEA HE ) but i doubt i will be able to get them to you by tommorow,
cant you try your local garage workshop for some as they usualy have a bucket or two of second hand nut/bolts
regards malcolm
MikeT
x 232
We can still get the thread tapped, bolt or not. I've certainly got a collection so may have some that will fit - you need two if I remember correctly.
Thanks for that vote of confidence Malcolm :lol:
I'm 99% sure I didn't have one single part left off except those that got renewed.
x 94
as i said earlyer Moke my many buckets of nuts and bolt are not from customers cars, as those have to go in the customers glove box, otherwise that's stealing
regards malcolm
x 8378
citronut wrote:as i said earlyer Moke my many buckets of nuts and bolt are not from customers cars, as those have to go in the customers glove box, otherwise that's stealing
regards malcolm
:lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
