Has anyone fitted bonett stays to a Xantia similar to the Peugeot 406.
Allan
bonnet stays
- x 8400
red_dwarfers
- x 58
ACTIVE8
- x 6
So there we have a PSA irony, on the one hand we have a car with a hydraulic/gas suspension system that has a single rod stay, while on the other hand we have a car with a more primitive suspension, that they saw fit to equip with a pair of struts to lift the bonnet.
ACTIVA
Deanxm
- x 87
Should be an easy job to do, its only a matter of fixing the mounting points to the bonnet and inner wing with a spot of weld or bolting.
Then you can all enjoy easy access 8)
and the big bill when the gas struts go limp and the bonnet falls on you
D
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
ACTIVE8
- x 6
The way an Xantia support is at the back, and out of the way means it does not make access that difficult.
So, although it could be tempting to adapt it, and do this, compare it to a stay which gets in the way more, mounted on the front slam panel, or a front hinged bonnet
I.E. BMW, Renault Kangoo style.
ACTIVA
addo
- Sara Watson's Stalker
- x 95
ACTIVE8
- x 6
I have not tried that, how far do the hinges let it go?addo wrote:Can you flip a 406 bonnet past the vertical, though? That's one of the Xantia's greatest assets IMO.
Does it go far enough to rest on the body with padding to protect the panels?
ACTIVA
addo
- x 95
ACTIVE8
- x 6
Hi addoACTIVE8 wrote:I have not tried that, how far do the hinges let it go?addo wrote:Can you flip a 406 bonnet past the vertical, though? That's one of the Xantia's greatest assets IMO.
Edit......
Well now with the benefit of hindsight the latter can't be done, as it should not be able to go that far.
If it had been in the morning as it was for you when you posted, I would have gone out, and checked it on my S2.
The fact that it opens like that sounds very useful.
I am aware of Mercedes doing this, as when the bonnet is open normally on their cars, the grill which goes up with it gets in the way as it hangs down as an L-shape, and I have seen an owner bang his head, who was not aware that it will open more, most of their models will open to a useful 90 degrees.
So I'm off out now to look at my "fanimold!"
ACTIVA
addo
- x 95
ACTIVE8
- x 6
Well good evening & many thanks to you for that information addo,
8) and owning an Xantia Activa I enjoy finding out its quirky traits, as long as they don't leave me in "Dire Straits"
Some might say that getting car that has spheres is "Money For Nothing" but I enjoy the fun of a great car, and see that others are missing the spherical point!
Also with having an Activa I notice that others are when they corner, the "Sultans Of Swing!"
So now I'm off to see my Activa's "Latest Trick."
8)
ACTIVA
- x 5672
- x 8400
addo
- x 95
