Some of you may have seen my post about my parents' Xantia 1.8i 8-valve car that had symptoms of blown head gasket after it got very hot. Wouldn't start after that. I was worried about that, and further investigation showed that somehow the valve timing was out - when crank locked with drill bit, cam was not at 10 o'clock position, but 2 o'clock position. It was fine when I last checked it, so something very bad happened. Haven't personally inspected belt to see if teeth missing. Anyway, told them that I thought it wasn't worth cost of repair what with needed new radiator and cylinder head cover (cracked around a stud), well as head gasket, valve timing change worrying, etc...
Upshot is that they bought a Xantia 1.9TD SX 1998 with 99,000 miles on the clock from some prat in a nearby town. Now found it has lots of problems after no one living around them helped with checking it over and they were finding it hard. Passenger window goes up but not down with local switch, but driver's side switch for passenger window works it. Glovebox handle broken. Neither passenger or driver door unlocking with key - spinning in lock. Key fob completely missing its guts. Anyone got a Haynes that covers Mark 2?!
My reason for this post is more to do with what I had described to me on phone from Spain tonight: they say engine is very noisy indeed, but main worry is that when idling on drive, they could here a loud ting-ting-ting noise, something they described as the sound you get when a fan surround isn't placed correctly and the blade keeps catching it. When they switched the engine off, the noise continued, dying away after the engine had already stopped, as though something still moving.
Diesels are not my forté...any idea what that could possibly be, continuing to make noise after the engine has stopped?
Thanks in advance,
