Xantia front wiper mechanism setting up
admiral51
(Donor 2026)
x 391
Unread post by admiral51 »
Hi all :)
Have just put the wiper motor/mechanism back into to place and i am having severe difficulties in getting the blades to sit correctly so they wipe the screen and not the scuttle :lol: :lol:
Im assuming that i can adjust the sweep as per the angle the blades are set at but im sure its the actual mechanism that ive set up wrong.
Does the motor only run for a set time and therefore is dependant on where the mech arms are provisionally set
Hope this makes some sense :lol:
Colin
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Disconnect the Wiper ARM mechanisem from the motor first!!!
Set the motor off so its goes to its PARK place which is ALWAYS in the same place... If youve had the small part from the motor to the mechanisem off, which has the Snap Clip nylon popper on it, you'll need to reset this and I THINK it points towards the FORWARD corner of the scuttle/ bonnet hinge area...
Once you've reset that small part up, you should be able to pop the main wiper mechanisem back on and it should be all ok...
I had this not so long ago, it took me a while to work it out and had to think about it logically... got there in the end..
Paul
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
i think i depends on were the short arm/link is set which is attatched by a 10mm nut directly onto the motor spindle,
remove the wiper arms completly, disconect the short link from motor spindle, set motor goine, then switch it off and work out were the spindles on the scutle (were arms fit onto) should be at park, then re/fit short link back on the motor spindle, if memery serves it should be horizontal, now tighten the 10mm nut and go for a dry run without wiper arms fitted, but whatch the spindles and see if they stop clean and dont go back the oter way at all
regards malcolm
admiral51
(Donor 2026)
x 391
Thanks Paul and Malcolm all is now sorted :D :D
The link rod has to be set horizontal and stretched away from its arm as this is the only way you can get the nut back on :)
If i had thought about it logically then i would have just popped the bonnet on one of my other Xantias to see how the link went :oops:
Colin
