Power steering failing on long journeys.
falling-out-with-my-car
x 25
Unread post by falling-out-with-my-car »
Hi, I drove probably my longest journey ever in my citroen Xantia 1.9 TD estate 1998, on April 4th, I made sure she had a good service the previous wednesday ready for the trip but low an behold 200 miles into my journey from Kettering to County Durham after being on pretty straight roads for very long periods the power steering started to seize in other words it felt very tight esspecially when I turned off into the services. after turnning a couple of tight corners normal power steering resumed.
we were towing a car transporter trailer which created the bumpiest ride ever until it was loaded with a GSA on the way back.
however I did not experience any problems with the steering on the journey back. My father has had a similar problem with his 1.9 TD P reg Xantia Hatchback again on a very long journey motorway driving.
has anybody got an explanation for this strange behaviour please? or perhaps there might be a problem with the system pressurizing properly.
after such a long journey my Xany is now dubbed ole faithful around 470 miles in one day I'm esspecially pleased with the car even after ownning her for five years.
regards, Nigel. :D
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Could it be the leakpast of your rear suspension elements, and a flat antisink sphere that cause the supply pressure issues?
What was the tongue weight of your loaded trailer? :shock:
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
I don't think its related to the suspension as the power steering has its own independent pressure supply direct from the pump, what it might be is early signs of pump or rack failure. I take it the universal joint at the bottom of the column is OK?
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 25
Dickie, yes the universal joint at the bottom of the colum is fine I had the colum out recently to see if I could get any closer to the dreaded clutch cable clip.
the car is well looked after LHM completely flushed every 2 years new spheres every five years, oil changes every 3 thousand miles, there is no problem with the ride or braking system and no faults with the steering now besides I don't live on a very long straight road. steering was absolutely fine today no problems at all.
The towing weight was certainly less than the weight of the estate car the loaded GSA weighs in at 950Kg and the trailer 350Kg, the haynes manual says the limit is 1200Kg but somehow I think thats wrong because the mass weight of xantias vary from 1480 to 2040Kg and the trailer nose weight can be from 75 to 85Kg. anyway weights asside the car was presenting with this problem before we loaded the GSA onto the trailer, I did point this out above in my orriginal question and there were no problems at all towing with a loaded trailer, we had it perfectly balanced.
the pwr steering on my Mk2 xantia has always been very light you could easily turn a corner just using your little finger on the wheel so the stiffness seemed a little strange.
regards Nigel.
reblack68
Unread post by reblack68 »
Maximum towing weight isn't related to the car's kerb weight. I believe it's something like the highest weight the car can pull from a hill start on a certain gradient.
Richard
Care of a 1994 205 D.
dnsey
x 19
Unread post by dnsey »
Your steering problem sounds like air in the system.
I guess that over a long distance on motorways it would have time to accumulate (say from a leaky sphere, etc), as the rack wouldn't be excercised much, but twisty roads would bleed any air from the rack 'on the fly'.
Are there any corresponding brake or suspension symptoms, and does turning the wheel lock-to-lock temporarily cure the problem?
x 25
dnsey, Ive driven the car 50 miles this mornning and no problems at all
yes the stiffness in the steering did dissapear when I turned the steering lock to lock in fact it disapeared completely and hasn't returned at all. seems fine now as if the problem never occurred at all, yet I know it did and as I said before my Dad experienced the same conditions whilst on the A1M and a journey of 200 miles. there are no corresponding brake or suspension symptoms, my rear pads are replaced every three years, front pads annually and there are no leaks in the hydraulic system, Ive had the torch out and had a good look underneath.
regards nigel.
