Changing over heater controls Xantia 96
vince
x 13
Unread post by vince »
Guys,
I can get the heater control panel "loose" but it is clear it cant be removed without disconnecting cables? from the back....
I presume i will need to whip out the stereo too....? Also once thats out how hard is it to disconnect the control panel and re connect?
I have a new one ready to go in you see... :P
Xaccers
x 188
Unread post by Xaccers »
you need to remove the radio, then you can pop off the black top cover of the controller, and inside disconnect the control cables.
DIY sphere tool
